Old 05-10-2004, 06:33 PM   #1 (permalink)
Date registered: Dec 2003
When and how was the W201 facelifted?
E V12 Nerd is offline   Reply With Quote
Old 05-10-2004, 07:59 PM   #2 (permalink)
Date registered: Jan 2004
Vehicle: 190E, 993
RE: When and how was the W201 facelifted?
In the U.S., it happened in '89. It added different front and rear bumpers and side body panels.
The different front bumper was now on both the 2.3 and 2.6. It involved a larger air inlet that extended almost the length of the bumper (see B) and a small (about 1") airdam (see A).
Early style (without an airdam and smaller air inlet area in the bumper):
Later style (with a small airdam and a larger air inlet area):
'87 190E
'97 993
'06 C230 Sport
Pawsh is offline   Reply With Quote
Old 05-11-2004, 01:41 AM   #3 (permalink)
Axel F's Avatar
Date registered: Mar 2004
Vehicle: w201 190D
yup
the w201 is facelifted between '88 en '89
he got other bumpers, long side panels.
The interior changed too.
In '92 i believe there was another facelift, then the steering wheel changed, and mercedes introduced a long middle console.
http://users.skynet.be/fa782220/voiture/index1.htm
Axel F is offline   Reply With Quote
Old 05-11-2004, 06:48 PM   #4 (permalink)
E-Klasse's Avatar
Vehicle: E320, SLK320, MKV Jetta TDI, Mini Cooper S
In the US, the headlight design were changed in 87 as well.
I assume no liability for any incidental, consequential or other liability from the use of this information. All risks and damages, incidental or otherwise, arising from the use or misuse of the information contained herein are entirely the responsibility of the user. Although careful precaution has been taken in the preparation of this information, I assume no responsibility for omissions or errors.
E-Klasse is offline   Reply With Quote
Old 05-12-2004, 09:40 AM   #5 (permalink)
Axel F's Avatar
Vehicle: w201 190D
here the lights have allways be the same
but the last have blinkers at the side u believe
Old 05-12-2004, 10:20 AM   #6 (permalink)
Vehicle: S430,190E 2.6,SL500
this is a bit off topic, but i believe prior to 1984 the 190's had dual arm wipers and after 85 they were single arm?
1983 200 (W123)
1985 190E (2.0)
1992 190E 2.6
1993 500SL
1994 SL500
2002 S430
2003 E320
190E2.6 is offline   Reply With Quote
Old 05-12-2004, 11:51 AM   #7 (permalink)
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280
190E2.6 - 5/12/2004 12:20 PM
There were two changes to the wipers. Prior to 1984, dual wipers were used. In 1984 the mono wiper was used with a single window washer nozzle. As of January 1985, the "jumping" monowiper and dual washer nozzles were used. The change increased the wiped area and the wiper was parked on the driver's side, so that the driver's view was cleared first. Due to the parts changes, including the hood, windshield mount, etc. it is not possible to swap systems.
MTI is offline   Reply With Quote
Old 05-12-2004, 12:03 PM   #8 (permalink)
Axel F's Avatar
Vehicle: w201 190D
yup
and before 85 i think the w201 had 14" rims
but indeed the side body panels were the bigest change.
