Old 03-27-2004, 11:35 AM   #1 (permalink)
Date registered: Mar 2004
Fuel Tank Sender
Fuel gauge isnt working. Where is the sender located underneath the car?
BigHeed87 is offline   Reply With Quote
Old 03-27-2004, 04:50 PM   #2 (permalink)
BenzWorld W126 & W201 Host
spanners's Avatar
Date registered: Feb 2003
Vehicle: 1988 420SE, 2002 C180 Kompressor, 200 ML320
Send a message via MSN to spanners
RE: Fuel Tank Sender
access is via the boot (trunk), remove the trim covering the fuel tank and you should be able to see the sender unit.
Work is the curse of the drinking class!
spanners is offline   Reply With Quote
Old 03-28-2004, 09:07 AM   #3 (permalink)
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280
As Spanner's said it's accessed thru the trunk by removing the felt wall at the back of the trunk. The sender itself is in the tank, however the wiring for the sender is located in the middle, top part of the fuel tank.
Here's a pic
MTI is offline   Reply With Quote
