Old 03-15-2004, 07:55 PM   #1 (permalink)
Date registered: Mar 2004
Help!! Emissions Check
I marginally failed the emissions inspection on NOx. The cause can be carbon build up or a faulty EGR. I called 2 MB parts dealers, they were quoting prices in the $380 to $450.
Has anyone replaced the EGR valve or know where it's located on a 1987 190E 2.3?
loroco is offline   Reply With Quote
Old 03-16-2004, 09:14 AM   #2 (permalink)
Date registered: Sep 2003
RE: Help!! Emissions Check
Don't pay me much attention, but if I remember well, it could be located inside the left wheel cover. Hope it helps.
Best regards
ssanmor is offline   Reply With Quote
Old 03-16-2004, 09:15 AM   #3 (permalink)
The left FRONT wheel, of course ;-)
Old 03-16-2004, 06:50 PM   #4 (permalink)
Thanks for the reply ... that's an odd place for an egr valve. It's usually by the intake manifold but I don't see it there.
Had snow today so I will take a look at the wheelwell this weekend.
Old 03-21-2004, 07:51 PM   #5 (permalink)
Removed the aircleaner assembly and looked again on the left side and don't see anything that resembles an egr valve.
I almost think there's no egr valve on this engine ('87 190e 2.3) BUT the MB parts dept quoted me a ridiculous price for one and Internet sites also list it but not one has a picture of this part for the 2.3 engine.
Confused .. need to check it since I failed the emission test on NOx.
Old 03-21-2004, 09:04 PM   #6 (permalink)
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
Well, that’s why he quoted you an insane price: the 2.3 L engine did not have an EGR until 1991, and they are ALL on the manifold.
1991 300 SE (w126.024/M103.981) 140,000 miles
jdc1244 is offline   Reply With Quote
Old 03-21-2004, 09:16 PM   #7 (permalink)
Date registered: Jan 2004
Vehicle: 190E, 993
The EGR valve is located on the exhaust manifold. If you noticed while searching the these online sources they list an engine number range (10 036977; 12 081514), this is when they started to install the EGR valves on the 2.3-8s.
'87 190E
'97 993
'06 C230 Sport
Pawsh is offline   Reply With Quote
Old 03-22-2004, 07:08 AM   #8 (permalink)
Thanks for the sanity check. Without an egr, where do I check for carbon buildup. The NOx level was slightly high (219 actual and 200 allowed).
Old 03-22-2004, 08:29 AM   #9 (permalink)
You restored my sanity.
Old 03-22-2004, 12:58 PM   #10 (permalink)
I'll check the engine # tonight, it should be outside this range.
