Old 03-15-2004, 01:26 PM   #1 (permalink)
VicsBenz's Avatar
Date registered: Mar 2004
Vehicle: '88 190e / 2.3
Help! Normal idle when Cold/ High idle when Hot
My '88 190e/2.3 idles at about 800 - 1000rpm after a cold start but once it warms up it won't drop below 1700rpm. In fact, it likes to race up to 2200 - 2500 rpm while in neutral but I hit the accelerator quickly to make it drop to 1700rpm.
Any ideas? Is this due to a faulty idle control valve? Would a faulty OVP relay cause the same behavior?
Heeellllp!!
VicsBenz is offline   Reply With Quote
Old 03-18-2004, 06:52 PM   #2 (permalink)
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
RE: Help! Normal idle when Cold/ High idle when Hot
I would say the idle control valve/unit – the bane of all eighties Mercedes with CIS e fuel systems. [:(] I had the same problem and a new valve and unit fixed it right up – hope this helps![:)]
1991 300 SE (w126.024/M103.981) 140,000 miles
jdc1244 is offline   Reply With Quote
Old 04-01-2004, 09:42 PM   #3 (permalink)
VicsBenz's Avatar
Thanks jdc1244, I'll give it a try.
Old 06-17-2004, 07:57 AM   #4 (permalink)
VicsBenz's Avatar
JDC,
Thanks for the reply. Sorry for the delayed response, I've not had access to my computer. Anyway, I'll give that a try.
Thanks,
Victor
Old 06-17-2004, 04:58 PM   #5 (permalink)
jdc1244's Avatar
You’ve still been suffering with the problem for almost three months…[:0][V]
Old 06-19-2004, 04:11 PM   #6 (permalink)
mykg4orce's Avatar
Date registered: Jun 2004
Vehicle: 1990 - 190E 2.6L, 2000 C230 Komp
how much does it cost to fix this kind of problem....my 190E 2.6 idles at 2000 RPM.
mykg4orce is offline   Reply With Quote
Old 06-20-2004, 06:22 PM   #7 (permalink)
jdc1244's Avatar
That’s insanely high – it cost me less than $400 to fix.
Old 06-22-2004, 10:08 PM   #8 (permalink)
Vehicle: The "GENERAL"
[?]Most probable cause ovp relay located behind battery compartment...[high idle problems, abs light on, etc.]
Going rate for an ovp relay @110 us dollars
89_190e_2.6 is offline   Reply With Quote
Old 11-09-2004, 10:52 AM   #9 (permalink)
VicsBenz's Avatar
Well, after seeing how much the Idle Control Valve cost for my '88 190e ($200+) I opted to try the OVP relay first ($70).
That really helped other problems but not the high idle. Alas, I found a place in Chicago called Ideal Auto run by a guy named Alex. I just ordered a used Idle Control Valve from him at a mere $35. I know, you get what you pay for, but I couldn't resist. I've bought parts from him before with no problem so I think the risk is minimal.
He ships fast so I expect to receive it within the next couple of days and will let you know if it does the trick.
Old 11-09-2004, 12:12 PM   #10 (permalink)
mykg4orce's Avatar
could you guys tell me where the idle control valve is? On this picture?
Owner of a 190e 2.6L
and 2000 C230 Kompressor
