Old 02-04-2004, 06:18 AM   #1 (permalink)
Date registered: Sep 2003
Pressure release in fuel tank
Hello all.
I have noticed that in my 190E 2.3 (1992) there is always a sudden pressure release in the fuel tank cap when I open it to put fuel.
I would like to know if it is normal that the tank pressure drops while it goes down or if, on the other hand, there is some problem or clogged pipe that should vent the tank and doesn't work. Any of the other cars I have owned does this.
Best regards.
ssanmor is offline   Reply With Quote
Old 02-04-2004, 08:48 AM   #2 (permalink)
BenzWorld W126 & W201 Host
spanners's Avatar
Date registered: Feb 2003
Vehicle: 1988 420SE, 2002 C180 Kompressor, 200 ML320
Send a message via MSN to spanners
RE: Pressure release in fuel tank
It is normal, and it is actually a vacuum not a prersure.
You should not run the engine with the fuel cap off as it affects the fuek pressure.
Work is the curse of the drinking class!
spanners is offline   Reply With Quote
Old 02-05-2004, 12:29 AM   #3 (permalink)
Thanks.
Best regards
Old 02-06-2004, 05:25 AM   #4 (permalink)
R170 Moderator and PITA
Bruce R.'s Avatar
Vehicle: 2002 SLK 32 AMG, bone stock. 1987 190E 2.3-16 Valve, NOT bone stock...
I beg to differ with you, here in the States anyway, it's pressure in the fuel tank.
U.S. EPA requirements include that automatic pressure tests be made on the fuel tanks of cars built after a certain date. These tests are what cause the "check engine" light to come on for no apparent reason. Reclosing the fuel cap often resets the light. There are occasions were the pressure is high enough to actually blow droplets of fuel out of the filler pipe, this is obviously a bad situation.
The reason I knowthat it's pressure is because I refuelled the car this morning, and got a face full of vapor...........[:0]
2002 SLK 32,
1987 190E 2.3-16 valve
"A vote is like a rifle: its usefulness depends upon the character of the user."
Theodore Roosevelt
"In any survival situation, you should try to keep your friends alive as long as possible. They stay fresh longer that way.
Unknown
Bruce R. is offline   Reply With Quote
