Old 12-30-2003, 11:04 AM   #1 (permalink)
Date registered: Dec 2002
Vehicle: Actually: R129/C126/ 2W124/S124/ C124/A124/C123/ 2W201/W115/W108
What is this conector?
Hi guys, the other day, cleaning my 190, i've discovered this connector under the front passenger floormat, anybody knows for what is this connector?
Charles
NEW!!! '91 560 SEC W126 (Really Full Equipe)
'95 E 320 T (W124) Automatic 5 Speed
'94 E 320 Coupé (W124) Automatic 5 Speed
'93 300 CE-24 Cabrio Sportline (w124) Automatic 5 Speed
'92 190E 3.2 AMG (1 of the 200 built)
'90 500 SL (R129) Panorama Hardtop
'90 190 E 2.6 Sportline (W201)
'90 300E 4Matic (W124)
'89 300 D Turbo (W124)
'84 280 CE (W123) 72.000 km
'75? 240 D 3.0 (W115)
'71 280 SE (W108) US Model
CHINCHE is offline   Reply With Quote
Old 12-30-2003, 11:46 AM   #2 (permalink)
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280
RE: What is this conector?
hard to say, since on certain years there's quite a few connectors on the passenger side (Engine Check reset, O2 sensor wires, etc.) but it could be the wire to the seat belt warning system which connects to the seatbelt buckle.
MTI is offline   Reply With Quote
Old 12-30-2003, 06:34 PM   #3 (permalink)
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
CHINCHE - 12/30/2003 1:04 PM
It's the oxygen sensor. The green single is the signal and the other two are the heater leads.
BENZDOC is offline   Reply With Quote
Old 01-01-2004, 11:01 AM   #4 (permalink)
And wich is their function... heated seats? If this is correct I've the instalation maded yet if I can get a pair of heated seats?
Old 01-01-2004, 11:57 AM   #5 (permalink)
MTI
MTI's Avatar
MBDOC is right, I didn't see that the plastic clip and the single sensor lead were connected. The O2 sensor is part of the fuel injection and emission system. With the O2 sensor disconnected or "out of the loop", after the car warms up (when the sensor would be getting to operating temperature0 you probably are getting bad gas milage and fouling the spark plugs with excess gas being sent to the cylinders.
