Hi everybody.
PROBLEM: My car does not start after I repaired its fuel distributor, just crank and crank.
CAR: 190E, 4CYL, 2.0, manual tans (4 gears), Bosch K-Jetronic (without lambda and CO sensor).
PREVIOUS FACTS:
1) I repaired the fuel distributor with a "Precision Machinery" repair kit. I think it works well. No fuel if there is not pressure in Air Throttle Plate. On the other hand, if I press the plate the fuel comes out nicely.
2) The first time I installed the repaired fuel distributor, the car started but I had to press the plate (2mm) and the throttle otherwise it died. After that, I turn the mixture (clockwise) until the plate had no play and the car start but the idle was very bad.
3) I played a little bit with the mixture but the car died and since then it does not start. The engine just cranks and cranks.
4) There is fuel coming out from the injectors. There is spark in each cylinder.!!
I dont know what happened and how to solve it. Furthermore, I am considering adjust the timing in case but I am not sure how to do it properly.
Thanks for the help, and sorry for my english
PREVIOUS FACTS:
