I have a 1991 190 e 2.3
i have installed
All new fuses
New water pump / gasket
New alternator
new coolant reservoir
New Head Gasket
Resurface / Pressure check / Valve Job Cylinder Head
New Intake/Exhaust Gaskets
New Thermostat
New OVP relay
New Cylinder Head Bolts
New timing Guide Rails (3 of them)
New Battery
All Vacuum lines Replaced ( i think had 2 of these cars)
New chain (not Installed)
for some reason i doubt the timing is set correct ( i did everything myself)
i do not want to damage anything by turning it on.
I need a mechanic to come double check
i have alternator and ect off so you can see timing marks fast..
I need you to do these things
1. Check Camshaft / Crank shaft / Distributor Timing marks are aligned properly :surrender:
2. Check that vacuum lines are install properly and are functioning
( one had a bolt in it before i replace)
3. Make sure OVP is causing any famous problems
4. If all seems to be ok but car isnt working check spark plugs to see if cross threaded
5. if all is a loss and valves are bent inform me.
Im in Gilroy Ca 95020
i want a real mechanic or some one who owns this car and can do this stuff
I can pay cash.
pick you up and drop you off
i will drive up to 100miles from gilroy FOR A REAL MECHANIC
I HAVE TO GET THIS CAR RUNNING SO MANY CAR BROKEN INTO HERE
i have installed
All new fuses
New alternator
New Head Gasket
New Thermostat
New OVP relay
New Battery
I can pay cash.
