Servicing manual transmission shift linkage - Page 2 - Mercedes-Benz Forum
post #11 of 19 (permalink) Old 07-31-2013, 08:22 PM
Date registered: Jul 2007
Didn't do the actual shifter yet. Where did you find the picture and parts for it? Having trouble with that.'
ddeamer is offline
post #12 of 19 (permalink) Old 07-31-2013, 08:48 PM
Supreme Sandwich
VaiFanatic's Avatar
Date registered: Aug 2010
Vehicle: '84 Euro 500SE, '85 Euro 2.3-16, '51 Euro 170S, '97 Jeep Wrangler Sport, '15 G63 AMG
Location: San Antonio, Texas/Gulf Breeze, Florida/Neustadt a.d. Aisch, Deutschland
Quoted: 627 Post(s)
When you get the bushings, it comes with instructions as well as a pretty detailed parts diagram.
Here's the MB diagram that you can look up on EPC:
'85 Euro 190E 2.3-16
'84 Euro 500SE
'51 Euro 170S
'15 G63 AMG
'98 Dodge Durango SLT+ 5.9L Magnum V8
~Josh
VaiFanatic is offline
post #13 of 19 (permalink) Old 12-26-2013, 12:08 PM Thread Starter
kahlil88's Avatar
Date registered: Dec 2009
Vehicle: 1985 Mercedes-Benz 190D 2.2 (717.411 5-speed)
Quoted: 27 Post(s)
Are these Delrin bushings worth the premium price? Not that I've had much luck finding other sources for bushings...at least not many that specify compatibility with 190E/190D. I keep hearing about bronze/brass bushings, or maybe these are the Delrin? I get paid tomorrow, so might as well service them.
Wanted
W201: Late model cladding clips, mushroom leather seat covers
For Sale
W123: Parts from 1982 300TD wagon
W201: Signal lamps, SRS airbag, mushroom rear seat
kahlil88 is offline
post #14 of 19 (permalink) Old 12-26-2013, 02:15 PM
Supreme Sandwich
VaiFanatic's Avatar
Quoted: 627 Post(s)
You can easily go to a shop and have some brass bushings made as long as they have something to reference. I think someone said they had a set made for $20.
'84 Euro 500SE
'51 Euro 170S
'15 G63 AMG
~Josh
post #15 of 19 (permalink) Old 01-16-2014, 05:41 PM Thread Starter
kahlil88's Avatar
Quoted: 27 Post(s)
Got the Delrin bushings, haven't installed them yet. I noticed that each bushing is 2 pieces, which makes installation easier, but are they as reliable? Suppose that I'll find out soon enough...
Wanted
For Sale
kahlil88 is offline
post #16 of 19 (permalink) Old 01-16-2014, 06:17 PM
Supreme Sandwich
VaiFanatic's Avatar
Quoted: 627 Post(s)
They are, you just need to make sure they snap in all the way. Some long needle-nose my help, especially when reinstalling the clips.
The bushings for the rods on the shifter side are easy. It's the bushings that connect the rods to the arms on the box itself where things get tight.
'84 Euro 500SE
'51 Euro 170S
'15 G63 AMG
~Josh
post #17 of 19 (permalink) Old 01-21-2014, 01:11 AM
mannys9130's Avatar
Date registered: Jul 2011
Vehicle: Blue/Blue 1985 190D 2.2 Auto, Red/Palomino 1984 190D 2.2 5MT
Quoted: 12 Post(s)
Yep, they're some sweet mojo. The delrin will be much better then brass in the long run. Delrin is self-lubricating and naturally slippery so you just install them dry and never have to grease them ever. The kit I got had the shift rod bushings and the shifter bushings for inside the actual shifter. REBUILD THAT SHIFTER. I promise you'll be glad you did. Mine was full of dried 30 year old grease AND dried 20-30 year old coffee. My shifter bushings were in the same condition vai's were in. Both had ripped and torn away internally. My shifter went from sticky, gritty, rough, stiff, and sloppy, to slick, precise, and natural feeling.
So on a 1-10 difficulty, I'd put it at a 3 star or maybe 4 because of the frustration of limited space. But on a scale of 1-10 smiles, you'll get the full 10 when you drive it after the install.
Just 3 tips:
Heed his warning about using small amounts of lube on the plunging section of the shifter assembly. If you goop it up it'll hydrolock and create suction ie it'll get stuck. Use just a regular anti-sieze compound grease to lubricate the shifter, but don't grease the delrin bushings.
Don't take the washers out of the cylinder above the shift arms. He has a warning in the instructions about that. They're hard to put back in. I just cleaned the area out as well as I could, and then applied lots of antiseize. It worked its way around the area just fine after exercising it a bit.
Finally, I never have good luck with allen heads. There are two allens that hold the retaining collar on inside the shifter. I got one out fine, but the other rounded off and I destroyed it when I finally got it out. I drove my mom's car down to the local Ace hardware and matched the allen bolts to the new ones they had in stock. I bought two pairs in case I take it apart again. I'd suggest replacing the bolts if you can because they're pretty easy to strip, and the replacements had deeper allen pockets.
That's all I got for now. Please update and let us know when you get the bushings installed!!! I want to know if you love them a little or a lot!
Das Beste oder nichts
mannys9130 is offline
post #18 of 19 (permalink) Old 01-23-2014, 09:29 PM
Date registered: Nov 2012
Vehicle: 85 190E eurobenz, 2.0L 4sp manual. sick and hiding in the trees
servicing manual transmission shift linkage
i question the use of antiseize lubricant. in my years i had repeat work that antiseize was used. it pushes out, does not stay where you put it. hardens up and is best used for exhaust or engine bolts. after temp extremes are experienced, it helps fasteners be removed the next time. so in other words, where the fastener experiences high friction while tightening, or extreme temp while operating i would use it. if i wanted smooth free movement of parts, there are good choices out there and less expensive. there is a teflon paste in a tube that can be found cheaply online. a teflon grease we used at GM, comes in a little paint can,(dont lick your fingers), or at FORD we had a specific caliper lube. equivalents can be had in sprays too. they dont contain aluminum filings like antiseize. in a pinch vaseline is the same as the trans lube the builders use for automatics. you just cant use it where petroleum is going to degrade the plastics or the neoprene or natural rubber. another thought is silicone dielectric. FORD uses it on bushings and caliper slides.
190Erur rur is offline
post #19 of 19 (permalink) Old 01-23-2014, 11:18 PM
mannys9130's Avatar
Quoted: 12 Post(s)
Fair enough, use what ever you see fit in your shifter assembly. The creator of the kit used anti-seize, has suggested it to all his customers, and nobody has had any issues including me. My shifter is so slick it makes me smile all the time. The anti-seize seems to be doing great in my situation. Would a white Lithium or Moly work? Yep, it isn't really a hostile envirinment in there, just a bunch of sliding points that need a little help with friction.
