722.4 transmission bushing - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W201 190 Class
Old 11-30-2012, 02:30 PM   #1 (permalink)
Date registered: Nov 2012
Here's an odd one. I took apart the 722.4 trans in my 1988 190D to track down why it won't shift into fourth gear. I found the reason, a failed Teflon o-ring on the K2 clutch support stub, which was allowing oil pressure to bleed off instead of engaging the clutch. The weird part is what i found in the front planetary. Assuming the pic I attached comes through, it shows the bushing that's installed in the sun gear of the front planetary. It's damaged, and i can't for the life of me figure out how or from what. It almost looks like it was damaged on installation, with hints of punch marks on the back (hidden in the image) edge. What i also don't understand is what this bushing actually does. The input shaft passes through, but the bushing doesn't appear to actually support the shaft in any way. Has anyone been inside one of these to the point of understanding all their details?
Richard
murphus is offline   Reply With Quote
Old 12-01-2012, 02:22 AM   #2 (permalink)
Metafly's Avatar
Date registered: Mar 2008
Vehicle: 1986 190D 2.5 5 Speed
Richard
I don't know the answer, but send me PM with your email, and i would be happy to send you two sets of MB trans manuals (.pdf). Michael
Michael
1986 190D, 5 Speed
1985 Porsche 928, 5 Speed (32v)
1980 Porsche 928, 5 Speed (16v)
So Cal
Metafly is offline   Reply With Quote
Old 12-01-2012, 05:43 AM   #3 (permalink)
Thanks Michael, I've sent you a note. I'll report back here what I find.
Old 12-01-2012, 08:38 AM   #4 (permalink)
Metafly's Avatar
On the way .
Old 12-01-2012, 09:07 AM   #5 (permalink)
I believe I've discovered the cause of the damage. The car is basically new to me, and clearly someone's been inside the tranny before as it's apparently missing an axial thrust bearing, thrust washer and washer that go into the clutch drum and provide surface for the snout on the front pump. That explains the damage. Too bad, i was hoping to rebuild it but now i think it's time to find a replacement. Anyone got a good source on MB auto trans, or better yet a 5-speed manual for conversion?
The pics show, in order (assuming they load as I wanted them to): Front clutch drum as it should be, with washers and axial bearing before installation; front clutch drum with washers and bearing installed; my drum as it came out with no washers or bearing; damaged snout on my front oil pump. Thanks to Marc for the pics of stock drum with correct parts.
Richard
722.4 transmission bushing-drum_with_parts.jpg   722.4 transmission bushing-drum_parts_installed.jpg   722.4 transmission bushing-drum_missing_parts.jpg   722.4 transmission bushing-pump_snout.jpg
Old 12-01-2012, 09:36 AM   #6 (permalink)
Metafly's Avatar
Richard
Bummer. This guy has been selling conversion parts on my local CL for awhile....Mercedes 190e Manual kit 5 speed
A little pricey, but...
There are tons of warrantied auto boxes on eBay motors. I bought a good used one from landautodismantling for $400 bucks that shifted great before my C class burnt to the ground.
Old 12-01-2012, 09:38 AM   #7 (permalink)
Nfsjunkie91's Avatar
Date registered: Aug 2010
Vehicle: 1991 300 SEL, 1987 190E 2.3, 1989 190E 2.6, 1989 560 SEC, 1985 380 SL
Murphus: Sorry about your luck, but I'm curious. Do you work on cars for a living, because I was impressed by how quickly you had your transmission stripped down!
Nfsjunkie91 is offline   Reply With Quote
Old 12-01-2012, 11:39 AM   #8 (permalink)
Metafly's Avatar
Richard, Just let me know if you want me to pull those parts from the trans I have in my garage. Might save you a few bucks.
Old 12-01-2012, 12:50 PM   #9 (permalink)
That's a great offer Metafly! However, I'll need more than the washers and the axial bearing. I'll also need the front pump and the front clutch drum as they're both damaged from the experience. And then I have to wonder how much metal is in the torque converter. Possibly very little, and possibly in a very fine state as it would have been mostly ground up, but... And no, to answer someone else's question, I'm not an auto mechanic, just stupid enough to not appreciate my limitations!
Richard
Bookmarks
