Fuel & air mixture screw - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-21-2012, 04:44 AM Thread Starter
Date registered: Sep 2009
Vehicle: 86 190e 2.3 8v with 120K
I had some work done at a shop and they said they played with the mixture screw on the throttle body. I can hardly sit at a light now without the car stalling. Where should the screw be so I can correct the problem instead of bringing it back to these idiots.
Squills is offline
post #2 of 11 (permalink) Old 06-21-2012, 07:42 AM
Nfsjunkie91's Avatar
Date registered: Aug 2010
Vehicle: '87 190E 2.3 Manual, '81 500SEL 4whl SLS, '91 300SEL
Quoted: 5 Post(s)
Take your air cleaner off, it's located here on the fuel distributor.
Provided your injection system is still functioning correctly, you should get a multi-meter with a duty cycle and then adjust according to this procedure: http://www.startekinfo.com/StarTek/o.../PDF/30006.pdf Job 7.3-105, subsection a. Browse the forums to find which pins on the diagnostic port you need to connect to.
W201 Euro + NAM Headlight Diagram. - Detailed OVP Information. Click only on OVP_Info.pdf. - W201 Differential Ratios
--- Mercedes Timing Chain Crimper (Single/Double Row) Tool for Rent. PM me for details. ---
Nfsjunkie91 is offline
post #3 of 11 (permalink) Old 06-21-2012, 11:21 AM
Date registered: Dec 2008
Vehicle: 1993 190E 2.6, 1990 300SEL, 1992 300SE, 1992 400E, 1987 190E 2.6 murdered by my brother.
Aww man...its a nightmare once they messed with the air fuel mixture. I have a factory sticker on my car that says it is preset at factory and do not adjust. You have to know what you are doing....and plug the volt meter set on duty cycle in that round circle with the cap by the ABS module. I would not go back to those guys anymore. Mechanics cheat by adjusting that screw instead of diagnosing and fixing the real problem. Make them pay for it....and take it to someone that knows 201s if you cannot do it.
There is one rule...there are no rules!
Runninrebel211 is offline
post #4 of 11 (permalink) Old 06-23-2012, 09:43 AM
Date registered: Feb 2009
Vehicle: 98 SLK230K AMG, 98 E55T, 89 2.5-16
yeah that mixture screw is always the fall guy when the mechanic can't find the real culprit
raymondgallant is offline
post #5 of 11 (permalink) Old 06-23-2012, 10:07 AM
slk230red's Avatar
Date registered: Mar 2004
Vehicle: '01 SLK230,'93 190E 2.3, 1971 LS5 Corvette Convertible
Quoted: 31 Post(s)
What work was done to your car? Yes, adjusting the mixture screw is just compensating for other issues, especially vacuum leaks. When the 2.3 is running right, you make them stall.
slk230red is offline
post #6 of 11 (permalink) Old 06-23-2012, 09:16 PM Thread Starter
I had the oxygen sensor replaced because i couldnt seem to get the stupid thing out. I also asked for them to check for vacuum leaks cause I could tell the car was not running right. Well after saying that they couldnt find any leaks I got a call the next day saying oh we think we found one at the throttle body and we played with the mixture to try and get it running better. Well it hardly ran. After reading up on how to adjust it I think I have it back to normal and checking the duty cycle I have it back to 70% which seems to be the normal.
Still not running well enough to drive but I know I will never bring the car back there!
Squills is offline
post #7 of 11 (permalink) Old 06-24-2012, 07:58 AM
slk230red's Avatar
Quoted: 31 Post(s)
The first thing I would do is check the vacuum hoses going to and from the Idle Control Valve. You want good soft hoses with tight connections.
post #8 of 11 (permalink) Old 06-24-2012, 08:15 AM
Gabodude's Avatar
Date registered: May 2012
Vehicle: Mercedes-Benz 190e 2.6
Quick thread jack... Where is the Idle control valve on the 2.6? ...thread jack over.
Gabodude is offline
post #9 of 11 (permalink) Old 06-24-2012, 08:23 AM
slk230red's Avatar
Quoted: 31 Post(s)
In front of the Fuel Distributor with a 2 wire connector plugged in to it.
Name:	2.6 fuel lines.jpg
post #10 of 11 (permalink) Old 06-24-2012, 08:50 PM
Gabodude's Avatar
Thank you, sir!
Gabodude is offline
