Coolant leak: Heater core suspect - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 05-09-2012, 07:28 PM Thread Starter
JSharp's Avatar
Date registered: Oct 2011
Vehicle: 1991 2.3 8v Desert Taupe Metallic
I've been losing coolant for a couple of months now. Never leave home without a jug of anti-freeze in the trunk.
Stopped by my mechanic this morning to get a diagnosis. I've been underneath the car enough to know that the leak comes from above the bellhousing which made me think the leak was in the vicinity of the heater core.
Once the car was on the lift the mechanic said definitely heater core and claimed the leak was coming through a venting tube piped from the core housing. He estimated replacement cost at $1,000. and figured he need three days from start to finish (10 hours total labor).
Okay I wasn't too surprised, but I'm wondering if there is any other explanation. There is no smell of coolant in the cabin. Heat works fine. No moisture or steam anywhere. Is it possible to have a coolant leak in the interior of the car and no signs or symptoms anywhere other than coolant loss?
Any thoughts appreciated. Thanks.
JSharp is offline
post #2 of 15 (permalink) Old 05-09-2012, 11:24 PM
Nfsjunkie91's Avatar
Date registered: Aug 2010
Vehicle: '87 190E 2.3 Manual, '81 500SEL 4whl SLS, '91 300SEL
Quoted: 5 Post(s)
Have you checked under the wiper cowl? It's possible the rubber hoses there are leaking.
If you really want to check if it's the heater core, get a large length of coolant hosing and bypass the heater core entirely, it's not terribly hard to do. At least that will isolate the leak and make it easier to work on the heater core.
If you have the ability, I'd recommend doing the heater core yourself. It only requires basic tools, a service manual and some patience. I did it myself about a year and a half ago, just need to pull the dash apart. A new OEM heater core was around 95 dollars from parts.com.
W201 Euro + NAM Headlight Diagram. - Detailed OVP Information. Click only on OVP_Info.pdf. - W201 Differential Ratios
--- Mercedes Timing Chain Crimper (Single/Double Row) Tool for Rent. PM me for details. ---
Nfsjunkie91 is offline
post #3 of 15 (permalink) Old 05-10-2012, 07:17 PM
beakerwsw's Avatar
Date registered: Apr 2012
Vehicle: 1992 190e 3.0 Auto (White)
There's a valve that controls how much coolant the heater core gets on the passenger side. If it leaks it will come out kinda behind the rear of the passenger wheel. The heater core is always good to replace (if it hasnt been done recently), but thats more of a 300$ job (with labor) rather than 1000. The replacement valve is like 20$ and takes about 45 minutes to replace.
Leaking coolant . . . . - 190 Revolution
beakerwsw is offline
post #4 of 15 (permalink) Old 05-10-2012, 08:03 PM Thread Starter
JSharp's Avatar
Pulled the heater control valve out today and put a lenght of straight hose in place. I don't seem to be losing any coolant, but I will need a couple of days to be sure. The valve was damp and the hoses were pretty ratty looking. I'm not sure if this is it, but I'm desperate to avoid ripping out that dash so I will replace the valve as soon as I can get it ordered.
JSharp is offline
post #5 of 15 (permalink) Old 05-11-2012, 03:32 AM
lomtevas's Avatar
Date registered: Nov 2006
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3 and 2015 GL350 BTC
Quoted: 55 Post(s)
Send a message via Skype™ to lomtevas
My recollection about heater cores comes from helping others repair theirs. Remember the car has two engine compartment bulkheads (forward and rear). I have never had to replace my cars' cores yet.
If the heater core is leaking, coolant will flow into the passenger compartment, not the outside of the rear bulkhead down to the ground. In my experience, such leaks come from the hoses that run from the engine compartment's bypass tube through the forward bulkhead to the core. So the $1,000 repair could be for a replacement of one of these hoses.
I suggest carefully removing the rubber trims and the plastic bug screen under the windshield. Carefully inspect the hose arrangement between the two bulkheads found to the rear of the battery. Those items costs pennies to replace and the dealers carry them in stock.
The home of the two 201's.
lomtevas is offline
post #6 of 15 (permalink) Old 05-12-2012, 07:22 AM Thread Starter
JSharp's Avatar
The dealer in Bridgewater called this morning. Heater valve is in. One day service. He says distribution warehouse in Robbinsville services the entire northeast. Interesting.
The dealer says he doesn't carry bulk heater hose. He suggested selling me the seperate lengths by part number but that is really expensive. Am I ok getting a good brand at NAPA? Do i need to be concerned about metric sizes in hose? Thanks.
JSharp is offline
post #7 of 15 (permalink) Old 05-12-2012, 05:03 PM
beakerwsw's Avatar
autohauz is super cheap, you can get pretty much all of them for like 20$
Your Parts Search Returned 0 Part(s) %26 Heat - Climate Control&gid=6892@Heater Hose
post #8 of 15 (permalink) Old 05-12-2012, 05:55 PM
AMGViper's Avatar
Date registered: Sep 2006
Vehicle: SLR
Send a message via AIM to AMGViper
NAPA is imported Chinese crap. Stuff from Azautohaus is typically from Germany or the surrounding areas
AMGViper is offline
post #9 of 15 (permalink) Old 05-12-2012, 07:07 PM Thread Starter
JSharp's Avatar
I'm really surprised to hear that. I thought it was all american.
JSharp is offline
post #10 of 15 (permalink) Old 05-15-2012, 03:55 PM
holmesuser01's Avatar
Date registered: Jul 2009
Vehicle: 1984 190E 2.3 engine Automatic, 2002 C240 2.6 Automatic
I did my heater core last year, 2011.
Found lots of repairs done wrong in there while I followed the service manual. Thoroughly cleaned everything as I went.
It took a total of 9 hours, over a Saturday and a Sunday.
I had my parts supplier get the OEM hoses for me. Glad I did, as the ones on the car were either hard as a rock, or mushy.
I washed the entire heater box assembly, cleaned the flaps and surfaces. Previous owners were smokers, and it showed.
I'm so glad that I went ahead and did this job. Everything is working properly, and more importantly, there are no rattles in the dash anymore!!
Jacques405 likes this.
holmesuser01 is offline
    Coolant plastic hose leak between black firewall(Heater Core Hose) omairtheman1 W220 S-Class 11 07-12-2015 12:51 AM
    Coolant still won't circulate to heater core? 500SEC_AMG W126 S,SE,SEC,SEL,SD,SDL Class 31 08-12-2013 11:52 PM
    No circulation through heater core after coolant flush edoubleu W124 E,CE,D,TD Class 1 04-28-2010 11:56 AM
    Another coolant leak question, Heater Core or Heater Core Valve?..... Nepenthe73 W201 190-Class 5 02-01-2009 05:18 AM
    Direction of coolant flow through heater core Stevenpfaff W123 E,CE,D,CD,TD,TE Class 0 01-29-2005 03:12 PM
