Cruise control/tachometer? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 01-31-2012, 06:37 PM Thread Starter
Date registered: Sep 2011
Vehicle: 1986 190D 2.5
Quoted: 5 Post(s)
Guys,
The tachometer as well as the odometer on my 190D aren't functioning. It's been that way when I got the car.
With the tach not working cause the cruise control not to engage? What about the odometer? Could it be at fault?
By the way, is there a dash light which illuminates whenever the cruise control is engaged?
Any advise is greatly appreciated.
Raymond
sunrays is online now
post #2 of 13 (permalink) Old 01-31-2012, 06:48 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
What light comes on when cruise control is on?
Also, have you checked fuse 10? Both the tach and the CC are controlled by the same fuse.
1979 Pontiac Firebird 5.7- 86,142 miles
1981 Chevrolet Corvette 5.7
1984 Mercedes 190D 2.2 Auto - 140,628 miles
1987 Chevrolet Sprint 1.0 - 139,000 miles
1989 Oldsmobile Cutlass Calais S - 123,000 miles
1989 Chrysler New Yorker - 95,000 miles
1991 Dodge Stealth R/T - 101,000 miles
1999 Dodge Durango - 178,000 miles
2003 Dodge Dakota - 203,000 miles
1984babybenz is offline
post #3 of 13 (permalink) Old 02-01-2012, 08:24 AM
dudeperson3's Avatar
Date registered: Jun 2009
Vehicle: 1992 190E 2.3 8v w/ '87 5-speed and 3.27 rear, 1966 Shelby Cobra 427 S/C
Send a message via AIM to dudeperson3
Post
There is no light for the cruise control.
I suggest you:
1. Remove all fuses
2. Nicely clean all contacts in the fuse box with emery paper or high grit sandpaper.
3. Install all brand new fuses
I swear, 70-80% of the issues I've had in my car for the 3 1/2 years I've had my 190 were due to fuses. I hate these continental fuses. If anyone ever finds GLASS fuses that have the tapered ends like our continental fuses...please tell me. I'll buy 100 of every amperage we need.
1992 190E 2.3 8v (converted to 5-speed)
27,045 miles as of 9/31/08
183,000 miles as of 2/1/15
1965 Shelby Cobra 427S/C (351W engine)
15.5k miles as of 2/1/15
My Auto>5speed Conversion Walkthrough
dudeperson3 is offline
post #4 of 13 (permalink) Old 02-01-2012, 08:52 AM
Date registered: Jan 2011
Vehicle: '85 W201.601; '13 X204.651
Quoted: 24 Post(s)
The fuse suggestion is the best bet. The odometer has no effect on the cruise, but the speedometer does. There is a Hall's effect sensor at the back of the speedo where the cable connects. Not likely it's defective but it could be.
The tachometer works off of a sensor on your flywheel, driver's side. No relation to the cruise. Cleaning that could help your tach. If checking and cleaning fuses doesn't work, the next best bet is the amplifier which sits under the floor mat at the passenger's side. That part has been upgraded multiple times from your original. Expensive part but generally found in wrecking yards much more reasonably. I have a later model direct replacement available should you need one.
NO.
Bob338 is offline
post #5 of 13 (permalink) Old 02-01-2012, 10:25 AM
JamesDean's Avatar
Date registered: Jan 2005
Vehicle: 93 190E 2.6; 82 300 SD Turbo
Quoted: 58 Post(s)
Would a bouncy speedometer needle cause the cruise control not to work? Ever since I got my 201 in 2006 the cruise hasnt worked and the speedo has always been bouncy a bit.
Cruise not working? Send me a PM. I may be able to help/fix it. Check here for compatibility, tips, diagnostics, component locations, and availability!
1982 - 300SD 144,000
1982 - 300SD 270,000
1989 - 420SEL 210,900
1989 - 560SEL 115,500
1990 - 300SE 263,000
1990 - 560SEL 156,000
1993 - 190E 3.0 225,000
1993 - 300E 191,000
JamesDean is offline
post #6 of 13 (permalink) Old 02-01-2012, 11:22 AM
Quoted: 24 Post(s)
Yep.
Your cable is probably kinked. Either lube it or replace it and that MIGHT be the CC problem.
Bob338 is offline
post #7 of 13 (permalink) Old 02-01-2012, 11:37 AM
JamesDean's Avatar
Quoted: 58 Post(s)
Originally Posted by Bob338 View Post
Yep.
They're pretty cheap right now, I've never replaced one before. I do have a spare cluster that I've been meaning to swap parts on to mine (temp/vac/something to fix my trip)
Ever replace a cable? Difficult?
1993 - 300E 191,000
post #8 of 13 (permalink) Old 02-01-2012, 11:53 AM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
Routing the cable up through the firewall isn't particularly hard, just a lot of "on your back" work.
MTI is offline
post #9 of 13 (permalink) Old 02-01-2012, 11:56 AM
JamesDean's Avatar
Quoted: 58 Post(s)
I remember removing this spare cluster from the 201 at the yard was fairly annoying. The cable had no slack in it and was a bear to loosen. i just dont want the same thing to happen here. It seems like installing the cable cluster end first, mounting the cluster than routing/attaching at the transmission is the best way.
1993 - 300E 191,000
post #10 of 13 (permalink) Old 02-03-2012, 02:45 AM
Vehicle: 1984, 201.122, OM601.921, G717.410
Replacing the speedometer cable is no guarantee that you will repair the cruise control. That is like trial and error with accupuncture.
I suggest troubleshooting the cruise control system using an electrical rather than a mechanical approach. Start in the middle and work out. (To guess a number between 1 and 100, start at 50).
On early models, the speedometer sensor on the back of the instrument cluster is a transformer, not a Hall sensor.
vishvamata is offline
Funny cruise control issue, wont cruise above 49MPH PictureMeRollin C215 CL-Class 3 01-31-2011 01:44 AM
No tachometer or cruise?Just quit Macdiesel W124 E,CE,D,TD Class 1 09-29-2010 03:11 AM
Transmission, Door Locks, Cruise Control, and Climate Control - Vacuums Woofy85 300DT W123 E,CE,D,CD,TD,TE Class 3 03-13-2009 04:44 AM
Faulty Tachometer, Cruise Control, Clock and kilometer gauge syednaimath W126 S,SE,SEC,SEL,SD,SDL Class 2 11-13-2006 04:25 PM
Cruise control display question. Does you car display the cruise control speed in the lower display? aquascape R171 SLK-Class 42 01-15-2006 01:37 PM
