Door lock button snafu - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-13-2012, 09:11 PM Thread Starter
Date registered: Sep 2011
Vehicle: 1986 190D 2.5
Quoted: 5 Post(s)
Howdy folks,
My first post with some reservations. New individual and owner of a 86' 190D 2.5. Recently noticed that when I try to lock the doors from inside/outside utilizing the key, the right rear door lock button doesn't retrack but the other three do.
I must manually push down the door lock button in question to lock the door and silient the vacuum pump. As I attempt to unlock the car from inside/outside, the lock button does extend to unlock the right rear door lock.
Could there be a vacuum door lock check value leak or defective solenold? Any suggestions of a fix would be greatly appreciated.
I apologize if the above message seems confusing.
Regards,
Raymond
sunrays is offline
post #2 of 6 (permalink) Old 01-13-2012, 11:34 PM
Dusty`NZ's Avatar
Date registered: Mar 2004
Vehicle: w115-240D, w115-300D, w201-190e (3), w123-300D w201-190d
sounds like the vacuum actuator in the door has failed.
'76 - 300D
'72 - 240D (noddy)
'40 Chev pickup
Dusty`NZ is offline
post #3 of 6 (permalink) Old 01-14-2012, 09:04 AM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
+1. Sounds like that's the problem.
1979 Pontiac Firebird 5.7- 86,142 miles
1981 Chevrolet Corvette 5.7
1984 Mercedes 190D 2.2 Auto - 140,628 miles
1987 Chevrolet Sprint 1.0 - 139,000 miles
1989 Oldsmobile Cutlass Calais S - 123,000 miles
1989 Chrysler New Yorker - 95,000 miles
1991 Dodge Stealth R/T - 101,000 miles
1999 Dodge Durango - 178,000 miles
2003 Dodge Dakota - 203,000 miles
1984babybenz is offline
post #4 of 6 (permalink) Old 01-14-2012, 11:39 AM
Nfsjunkie91's Avatar
Date registered: Aug 2010
Vehicle: '87 190E 2.3 Manual, '81 500SEL 4whl SLS, '91 300SEL
Quoted: 5 Post(s)
I believe it's also possible that the vacuum hose itself may have a leak in it.
W201 Euro + NAM Headlight Diagram. - Detailed OVP Information. Click only on OVP_Info.pdf. - W201 Differential Ratios
--- Mercedes Timing Chain Crimper (Single/Double Row) Tool for Rent. PM me for details. ---
Nfsjunkie91 is offline
post #5 of 6 (permalink) Old 01-15-2012, 07:29 AM Thread Starter
Quoted: 5 Post(s)
Guys,
I appreciate the quick response to my inquiry. Question, does each door has its own vacuum actuator? If so, where in the door compartment will I locate it? Is it somehow attached to the solenoid?
I have a Haynes service & repair manual but I see no reference or picture of a vacuum actuator for the door.
Once again I thank you all for your time and effort in suggesting a possible fix.
Regards,
Raymond
sunrays is offline
post #6 of 6 (permalink) Old 01-22-2012, 04:00 PM Thread Starter
Quoted: 5 Post(s)
Door lock button snafu repaired
Guys,
First of all I want to thank you all for the input provided to reslove the problem I was having with the door lock button.
I removed the vacuum actuator (solenold) from the right rear door and replaced it with one that I got from pick & pull. All is well now with the replacement.
My concern is the vacuum/supply pump. It takes about one minute for it to shut off after I lock the doors either from within or utilizing the key. The sound is most noticeable (loudest) behind the fuel fill door. Is this normal? I'm concern that the battery will quickly drain after repeated use of the central locking system.
As I look through the Hayes manual I think the culprit is either the vacuum/suppy pump or the fuel tank flap actuating element. What do you guys think?
Possible solutions/advice as always is greatly appreciated.
Regards,
Raymond
sunrays is offline
    Drivers Door Outside Lock Button stclarke R230 SL-Class 3 11-30-2011 06:13 AM
    door lock button azgent General Mercedes-Benz 4 10-19-2011 09:10 AM
    DOOR LOCK/UNLOCK BUTTON NOT WORKING BIZYGUY W140 S-Class 3 03-15-2010 10:19 AM
    Power door lock button vip-ucf W140 S-Class 3 02-22-2010 11:56 AM
    how do you remove door lock button covers on W220 126 fan W220 S-Class 0 03-05-2008 11:43 AM
