W201 Blower Motor Control Switch - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-06-2011, 06:12 PM Thread Starter
PapaVoodoo's Avatar
Date registered: Oct 2011
Vehicle: 1989 190E
I've searched the forums and browsed the FAQs but can't seem to find a thread of instructions on how to remove the blower motor control switch located above the climate control module. I undid the top and bottom screws, took out radio and ashtray and took off the rubber knob on switch but something still seems to be holding it all in and can't figure it out. anyone have a link to a diagram or video? Thanks
PapaVoodoo is offline
post #2 of 3 (permalink) Old 11-13-2011, 06:55 PM
Date registered: Mar 2011
Vehicle: 1986 2.3 A/T 102.985 vin DA28D5HF284301
Take the center vents off, you'll find two screws at the bottom that attaches the upper panel assy for the blower control switch. Take the power window/side mirror panel off, you will find 8mm bolt that attaches the lower panel assy. Remove the panel below the glove box compartment as well. All these removed, you'll have extra space to take the center console out, just enough to access the blower switch. Unplug the harness, remove the rubber knob, pry up the wood panel and you'll find two screws that holds the blower switch. Remove the switch from the aft face of the console.
Hope this helps. I repaired a stuck up control switch just last week.
tab688 is offline
post #3 of 3 (permalink) Old 11-14-2011, 12:24 PM Thread Starter
PapaVoodoo's Avatar
Vehicle: 1989 190E
I found out what my problem was thanks all. There were a total of 4 screws I had to remove at the bottom. Two were kind of hidden behind and below the ashtray screws. Newish switch installed and working great! Now to replace my center console passenger p/w switch assembly!
hot air blower motor stop working E190 w201 selver W201 190-Class 6 01-05-2015 01:54 PM
Weird blower motor problem. Won't switch off decampos R/C107 SL/SLC Class 13 06-08-2014 11:06 AM
Heat / Blower Motor Switch - Any Good Tests? quantass W201 190-Class 0 12-28-2010 03:11 PM
No Blower Motor Control - 88 560sel greyfoxmc W126 S,SE,SEC,SEL,SD,SDL Class 0 11-14-2006 01:58 AM
Blower motor/"switch" fries: anybody else? Dick R170 SLK-Class 3 08-02-2001 10:33 AM
