Wheel Makes Noise -- Bleed Brakes OR Caliper? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-23-2011, 09:25 AM Thread Starter
Date registered: Sep 2009
Vehicle: '91 Merc 190E 2.3
Question Wheel Makes Noise -- Bleed Brakes OR Caliper?
I own a 1991 Mercedes 190e 2.3 (automatic, 4dr) here in Canada. While driving or while applying the brakes I can here a scrubbing / knocking noise coming from the right-rear wheel. On first driving there is nothing but once i hit greater than 60 kph the noise can be heard and remains on while driving, though quieter when driving slower, and gets louder while applying the brakes. There are no other symptoms to speak of -- brake pedal is fine, brake fluid is topped up, checked all pads and caliper.
Someone suggested two things:
1. Bleeding the brakes
2. Replacing the caliper
For my vehicle how exactly do i go about bleeding the rear-right brake?
Thanks
quantass is offline
post #2 of 4 (permalink) Old 05-23-2011, 10:31 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
The first thing I would suggest is tearing into it a bit to make sure something isn't worn out or missing, maybe a pin is dislodged, perhaps the dust seal has cracked and the piston/bore is corroded and sticking, etc.
After all if you have to replace the caliper you'll bleed it then.
Good luck.
Check Codes is offline
post #3 of 4 (permalink) Old 05-24-2011, 10:04 PM Thread Starter
It is tough for me to identify what is causing the scrubbing / thumping unless the wheel is in fast motion.
How safe is it for me to have the car on jack stands (both rear wheels), have the car in drive, then step on the gas + apply brakes in order to hear - locate the issue with the rear right wheel?
quantass is offline
post #4 of 4 (permalink) Old 05-24-2011, 10:14 PM
1984babybenz's Avatar
Date registered: Nov 2009
Vehicle: 1984 190D 2.2
Do you have anti squeal stuff on the back of the pad?
How to bleed the brakes:
-Run a hose from the bleeder valve to a plastic water bottle partially filled with brake fluid
-Have one person slowly push in and let out the pedal while another is keeping the reservoir filled
-When they are pushing down, you open the bleeder valve to let the fluid come out.
-When they begin letting go of the pedal, close the bleeder valve so no air or old fluid goes back in.
Keep bleeding until you see no air bubbles, and the fluid is clear.
If you haven't replaced the fluid in awhile, do this for all four calipers.
1979 Pontiac Firebird 5.7- 86,142 miles
1981 Chevrolet Corvette 5.7
1984 Mercedes 190D 2.2 Auto - 140,628 miles
1987 Chevrolet Sprint 1.0 - 139,000 miles
1989 Oldsmobile Cutlass Calais S - 123,000 miles
1989 Chrysler New Yorker - 95,000 miles
1991 Dodge Stealth R/T - 101,000 miles
1999 Dodge Durango - 178,000 miles
2003 Dodge Dakota - 203,000 miles
1984babybenz is offline
    Rear Brakes - Stripped the Caliper to Wheel Bearing Screw keepsitsimple W202 C-Class 8 06-22-2011 03:48 PM
    1984 300D turbo hot wheel! Brakes failed!! Sticky caliper? morav W123 E,CE,D,CD,TD,TE Class 5 02-21-2011 06:12 AM
    E320 Steering wheel makes a scraping noise Henrick W210 E-Class 12 01-29-2011 10:31 PM
    brakes makes noise larces W210 E-Class 5 02-14-2008 02:15 PM
    steering wheel makes groaning noise ProV1x W210 E50 AMG, E55 AMG 13 11-13-2007 01:10 PM
