What happened to the MB part numbers for the headlights posted a while back?
Fred, check your PM.
5 A 201 820 03 61 LIGHTING UNIT
Replaced_By: A 201 820 71 61 -
5 A 201 820 71 61 LIGHTING UNIT
LEFT,LEFT-SIDE TRAFFIC
BOSCH 001
5 A 201 820 04 61 LIGHTING UNIT
Replaced_By: A 201 820 72 61 -
5 A 201 820 72 61 LIGHTING UNIT
RIGHT,LEFT-SIDE TRAFFIC
BOSCH 001
11 A 002 826 86 90 .LENS
LEFT HEADLAMP 001
11 A 002 826 87 90 .LENS
RIGHT HEADLAMP 001
20 A 001 826 56 78 .REFLECTOR
LEFT HEADLAMP
BOSCH 001
20 A 001 826 57 78 .REFLECTOR
RIGHT HEADLAMP
BOSCH 001
23 A 001 826 04 82 .LAMP SOCKET
Replaced_By: A 000 545 23 19 -
23 A 000 545 23 19 .SOCKET
PARKING LIGHT
BOSCH 002
26 A 000 820 00 49 .CAP
LEFT
BOSCH 001
26 A 000 820 01 49 .CAP
RIGHT
BOSCH 001
29 A 001 826 58 78 .REFLECTOR
FOGLIGHT
BOSCH 002
32 A 001 826 19 80 .SEAL
LENS
1025 002
35 A 001 826 20 80 .SEAL
Replaced_By: A 001 826 32 80 -
35 A 001 826 32 80 .SEAL
COVERING
625 MM 002
38 A 000 800 51 75 .ELEMENT
Replaced_By: A 000 800 68 75 -
38 A 000 800 68 75 .ELEMENT
LIGHT RANGE ADJUSTER
OptionPart_With: A 000 800 51 75 002
41 A 000 820 98 21 .BLINKER LAMP
Replaced_By: A 201 826 00 43 -
41 A 201 826 00 43 .BLINKER LAMP
LEFT 001
41 A 000 820 99 21 .BLINKER LAMP
Replaced_By: A 201 826 01 43 -
41 A 201 826 01 43 .BLINKER LAMP
RIGHT 001
44 A 001 826 21 80 ..SEAL
LEFT
BOSCH 001
44 A 001 826 22 80 ..SEAL
RIGHT
BOSCH 001
47 A 000 826 84 82 .LAMP SOCKET
BLINKER LIGHT
BOSCH 002
50 A 000 826 59 84 .SPRING 004
53 N 072601 1012803 BULB
Replaced_By: N 000000 0000374 -
53 N 000000 0000374 BULB
HIGH/LOW BEAM
H4-12V 60/55W 002
56 N 072601 1012290 BULB
FOGLIGHT
YC-12V 55W 002
59 N 072601 1012900 BULB
SIDE MARKER AND CLEARANCE LIGHTS
T4W - 12V 002
62 N 072601 1012190 BULB
BLINKER LIGHT
P21W - 12V 002
68 A 201 826 07 80 SEAL
LEFT LIGTHING UNIT 001
68 A 201 826 08 80 SEAL
RIGHT LIGTHING UNIT 001
71 A 201 826 00 00 MOUNTING MATERIAL
LIGHTING UNIT 002
74 A 201 820 00 14 BRACKET
LIGHTING UNIT TO WHEELHOUSE 002
77 A 201 990 00 15 SCREW
80 N 914031 1004311 COMBINATION BOLT
Replaced_By: N 000000 0000927 -
80 N 000000 0000927 SHEET METAL SCREW
LIGHTING UNIT TO LATERAL STIFFENING 004
83 A 123 994 05 45 LOCK
86 A 201 826 00 71 SCREW
89 A 108 990 00 57 NUT
BLINKER LIGHT TO LIGHTING UNIT 002
