Swap a 2.6L engine in 4 cyl 190E? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-29-2010, 08:23 AM Thread Starter
1899's Avatar
Date registered: Mar 2010
Vehicle: 97 E420 / 84 190E 5spd / 09 Smart Brabus
Quoted: 2 Post(s)
Has anyone done a 2.6L conversion on a 4cyl Mercedes? These engines seem to be plentiful. The 4 cyl is pretty good for me but where I live the car is too old to get emissions so i can basically put whatever I want under the hood. Its a 5 spd. How difficult would it be? I assume no fabrication? are we looking at removing the front end to slide the engine in? I guess it would be best to get a wrecked car? Shortened driveshaft? same 5spd trans will bolt up? according to the EPA, its only a 1 MPG hit.
I thought it might be a good winter project
1899 is offline
post #2 of 6 (permalink) Old 09-29-2010, 08:42 AM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 426 Post(s)
The radiator, cross member, AC condenser, hood latch, flywheel and a few other parts are totally different.
87 300D turbo + 5spd
93 190e 2.3 + Megasquirt 1
92 190e 2.6 5spd + Megasquirt 2 (parted out, history)
97 E300 DIESEL
tjts1 is offline
post #3 of 6 (permalink) Old 09-29-2010, 10:04 AM
scottx's Avatar
Date registered: Apr 2010
Vehicle: 85 190e/8v & 89 420 SEL
Send a message via AIM to scottx
Should be a fairly simple swap since it's all bolt in basically. No fabrication work needed if you have a good 2.6 donor car to get parts from.
That's really a good idea and one I think I'm going to look into further. I might swap my engine if I could find the right 2.6 car that's wrecked and cheap.
Professional Mobile Electronics Installer & Fabricator [R]
Champagne Dream - w201.024 - http://www.ChampagneDream.org/
scottx is offline
post #4 of 6 (permalink) Old 09-29-2010, 10:37 AM
tjts1's Avatar
Quoted: 426 Post(s)
A 6 cylinder dual mass flywheel will be the hardest part to find.
97 E300 DIESEL
tjts1 is offline
post #5 of 6 (permalink) Old 09-29-2010, 02:43 PM
Date registered: Jul 2008
If you're going to go to the trouble of fitting a six cylinder, you might as well drop in the 3 litre M103 engine from the 300E if you get them over there. Fairly common conversion in New Zealand.
fatmikenz is offline
post #6 of 6 (permalink) Old 09-30-2010, 04:29 PM
insame1's Avatar
Date registered: May 2009
Vehicle: 92 190e 2.6 Sportline, 2006 c55
Quoted: 44 Post(s)
the springs and struts, ecm, and wire harness. and the cross member on the 2.6 is welded on instead of bolted. I would think you need new motor mounts also. another thing is the horn location is different. this is what I can think of at work but i bet there is more.
+1 on that there is no reason to do the 2.6 when the 3.0 would be the same amount of work with a better results in the end.
Never say Die.......
insame1 is offline
    190E ENGINE SWAP ceed W201 190-Class 20 08-31-2012 08:58 AM
    190e engine swap with 300e engine -increase HP The Melmaan W201 190-Class 16 11-05-2008 09:23 AM
    86 190E 5 speed to 88 190E automatic engine swap Benz Sage W201 190-Class 13 07-21-2008 08:20 AM
    190E 2.3 Engine Swap? cyberdyne W201 190-Class 3 06-08-2007 10:16 AM
    6 cyl.diesel to 5 cyl. diesel engine swap getgsd W126 S,SE,SEC,SEL,SD,SDL Class 4 09-08-2006 03:15 PM
