2.6 190E Fuel Pressure Regulator Question - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-14-2010, 12:47 PM Thread Starter
Date registered: Jun 2010
Vehicle: '89 190E 2.6
The regulator has a fitting at one end and what appears to be a vac line on the other. Where does thing go? I found this dangling free when replacing the ignition wires. The wire job was a flop! The car was running great with the ancient wires and now the #6 isn't firing under 1500 rpm. Swapped back in the old wire without success so I screwed something up.
T Love is offline
post #2 of 4 (permalink) Old 06-14-2010, 07:49 PM
Date registered: Jul 2009
Vehicle: 92 190E 2.3 SOLD, 91 420SEL, 95 C280
It connects to a tube that goes from the valve cover to the ICV & to the air cleaner. take a close look at that and you should see the fitting for it, careful it is plastic and probably brittle.
Landscape is offline
post #3 of 4 (permalink) Old 06-14-2010, 07:56 PM Thread Starter
Thanks. I will open it up again in the morning and take a closer look. I did connect the loose end to the breather hose from the vc to the air box (there was a vacant hole there) and got no improvement. Thanks for the response.
T Love is offline
post #4 of 4 (permalink) Old 06-14-2010, 09:10 PM
Date registered: May 2010
Vehicle: 1990 190E 2.6
check your #6 plug. you might have cracked it.
mitchell.huang is offline
fuel pressure regulator garysalas W126 S,SE,SEC,SEL,SD,SDL Class 1 04-27-2010 04:24 PM
Fuel Pressure Regulator question triskaideka W210 E50 AMG, E55 AMG 4 04-19-2009 09:42 PM
Need help with fuel pressure regulator bradk1 General Mercedes-Benz 4 09-29-2008 11:01 AM
Need a fuel pressure regulator for a 190E Scott-thundercat For Sale/Wanted/Trade/Giveaway 1 04-06-2006 02:59 PM
Fuel pressure regulator question.... Jordan R170 SLK-Class 4 09-26-2002 10:35 AM
