Location of 190e Crank Position Sensor - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 05-05-2010, 10:47 AM Thread Starter
Date registered: May 2010
Need to change out a crank position sensor. Anyone know how to get to it?
Berkemeier is offline
post #2 of 14 (permalink) Old 05-05-2010, 10:54 AM
IR MODERATOR
Jippi's Avatar
Vehicle: 1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
Quoted: 4 Post(s)
Send a message via AIM to Jippi Send a message via MSN to Jippi
model? year? motor?
1993 MB 190E 2.3 105k- its alive.. 1996 Volvo 855 GLT-R 350k still rolling
1998 Subaru Outback SUS 210k- Daily Driver 2011 Toyota Camry XLE 36k
1991 BMW 525I stock as stock gets 98k (Wrecked) 1998 MB C230 209k possessed by the devil
Benzworld.org---Tri-State Crew
Jippi is offline
post #3 of 14 (permalink) Old 05-05-2010, 10:56 AM Thread Starter
1991 190E 2.3
post #4 of 14 (permalink) Old 05-05-2010, 10:57 AM
IR MODERATOR
Jippi's Avatar
Quoted: 4 Post(s)
rear of the motor under the intake screwed into the opening in the block.
Jippi is offline
post #5 of 14 (permalink) Old 05-05-2010, 10:59 AM Thread Starter
Thanks!
post #6 of 14 (permalink) Old 05-05-2010, 12:16 PM
slk230red's Avatar
Date registered: Mar 2004
Vehicle: '01 SLK230,'93 190E 2.3, 1971 LS5 Corvette Convertible
Quoted: 31 Post(s)
Easiest way is to start at the Ignition Control Module and trace the cable back to the rear of the engine.
slk230red is offline
post #7 of 14 (permalink) Old 05-05-2010, 12:24 PM
Date registered: Sep 2007
Mine goes to the distributor, does that mean I don't have one on my model.
cypress188 is offline
post #8 of 14 (permalink) Old 05-05-2010, 01:24 PM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 426 Post(s)
Yup. Early cars didn't have timing windows on the flywheel.
87 300D turbo + 5spd
93 190e 2.3 + Megasquirt 1
92 190e 2.6 5spd + Megasquirt 2 (parted out, history)
97 E300 DIESEL
02 C320 VAGEN :the ugly one!
tjts1 is offline
post #9 of 14 (permalink) Old 05-05-2010, 01:44 PM Thread Starter
Okay, so I located the ignition module with the attached cables. Im guessing that the CPS is the one at the top right of the photo (see attached). I diconnected the cable and tried starting the engine, but it would not fire up. When I reconnected the cable the engine started better than it has in a long time. After a few more times, the engine began to stall out and I had too rev it to keep it running. All of this seems to point to the CPS, could it possibly be anything else? I know I also have to change the Cam Position Sensor at some point. Thanks for all of the help.
post #10 of 14 (permalink) Old 05-05-2010, 01:53 PM Thread Starter
CPS on Ignition Module
    Crank Position Sensor Location? revnobody W201 190-Class 3 04-08-2010 08:35 PM
    2003 CLK 500 crank position sensor location boatguy94 C209/A209 CLK-Class 4 11-26-2008 05:47 PM
    crank angle sensor or crank position sensor Gwagensofli G-Class 1 07-31-2007 03:37 PM
    Crank Position Sensor Location? Dolphin27 R170 SLK-Class 7 02-01-2007 11:45 AM
    Crank Position Sensor ghitos73 W163 M-Class 3 10-07-2004 09:15 PM
