Need advice on Fuel Pump Check Valve - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 11-15-2009, 08:23 AM Thread Starter
Date registered: Apr 2008
Vehicle: 86 Mercedes 190e 89 Mercedes 300e
Putting on a new fuel filter, fuel pressure regulator and fuel pump check valve on my 86 190e 8v. The new check valve has 17mm nut made on it install. The check valve in the pump doesn't have the 17mm nut made on it. Looks like it just threads into the fuel pump but just not sure how to remove. I've installed these before on my 300e but the valves on the pumps had the nut. Any thoughts or suggestions would be very appreciated.
jmiller689 is offline
Intermittent Start Issue, Fuel Pump? Check Valve? 93 300CE NeonDiary W124 E,CE,D,TD Class 9 09-05-2009 12:02 AM
Fuel pump check valve GotTheBenz W126 S,SE,SEC,SEL,SD,SDL Class 2 08-28-2007 02:05 PM
Replacing Fuel pump check valve NewMBie W126 S,SE,SEC,SEL,SD,SDL Class 0 11-25-2004 10:22 AM
Fuel Pump Replaced, Still Not Running, Fuel Check Valve? baco99 Vintage Mercedes-Benz 7 09-25-2004 06:17 PM
Fuel Pump and Check Valve RKS W126 S,SE,SEC,SEL,SD,SDL Class 0 06-10-2004 10:12 AM
