1985 190D Rough Idle Problem - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 11-11-2009, 08:24 PM Thread Starter
ROLLGUY's Avatar
Date registered: Dec 2006
Quoted: 2 Post(s)
I have been having an idling problem with my 190D lately. I have had to raise the idle to about 1,000 RPM in order to smooth it out. I have tested a few things to find out the problem. I replaced the 4 injectors with known good ones, no change. I loosened one injector line at a time when idling, and the engine stumbled with each one (telling me there is no dead cylinder). The engine seems to have the same power as before (not much), but just does not idle smooth. Does anyone have any ideas? Any help would be appreciated. Thanks, Rich
ROLLGUY is offline
1985 300SEL Rough Idle CraigTPE W126 S,SE,SEC,SEL,SD,SDL Class 10 03-27-2012 12:33 PM
190D Rough Idle Until You Turn Lights On? my380sl W201 190-Class 0 05-28-2008 07:02 AM
rough idle problem solved Pariso W203 C-Class 0 03-09-2007 09:11 AM
1985 190d ignition problem skyy BenzWorld Help 0 05-23-2004 07:23 PM
problem with rough idle robw126 W126 S,SE,SEC,SEL,SD,SDL Class 3 11-08-2002 06:25 AM
