Any connection between Fuel, Temp & Oil pressure Gauuges? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 11-04-2009, 03:27 PM Thread Starter
ebaftj01's Avatar
Date registered: Jan 2005
Vehicle: 1983 240D daily driver, 1987 560SEL sold, 1988 190E 2.3, 1989 190E 2.6 sold, 1995 E320, 2000 S500
Is there any connection between fuel, temp & oil pressure gauges on a 88 2.3? They all stopped working at the same time (I noticed them this morning). I thought they work on vacuum lines. Can it be something electric? The weird thing is they all stopped working at the same time. The clock, tachometer, speedometer, and even the fuel economy gauge work fine. I need to know where to start looking because I don't want to break anything in the instrument cluster.
ebaftj01 is offline
post #2 of 7 (permalink) Old 11-04-2009, 03:29 PM
LAMF's Avatar
Date registered: Jul 2006
Vehicle: 96 C36, 87 Turbo'd 190E 2.3-16, 86 SC'd 190E 2.3-16, Brabus'd C32
fuse
87 190E 2.3-16 Cosworth- Track car-Getrag, short shift, delrin, 95a poly, Euro'd, 2 tone Recaros, custom suspension, EFI w/ Megasquirt, cast iron headers, Garrett turbo...
86 190E 2.3-16 Cossie-Old beater Getrag, slammed on BBS' Mosselman ECU, Eaton M62 SC
03 C32 ///AMG - Daily- designo edition, command, fulll Brabus CF interior, CF lips mirrors spoilers ect, and enough engine mods to destroy 911's
LAMF is offline
post #3 of 7 (permalink) Old 11-04-2009, 04:16 PM Thread Starter
ebaftj01's Avatar
Thanks LAMF, I will check that tomorrow morning. I feel embarrased I didn't give it thought, thinking it was more involved (vacuum line etc) but that would explain why they went out at the same time, eventhough they aren't really related function wise.
Thanks again.
ebaftj01 is offline
post #4 of 7 (permalink) Old 11-04-2009, 04:54 PM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
If it's not the fuse, it could also be a broken grounding point. There's a physical connection between the left cluster and the center/right clusters that provides neg ground. Simple test is to slap down on the dash above the cluster and see if the instruments "spring to life" temporarily.
MTI is offline
post #5 of 7 (permalink) Old 11-05-2009, 01:21 AM
IR MODERATOR
Jippi's Avatar
Vehicle: 1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
Send a message via AIM to Jippi Send a message via MSN to Jippi
could be a bad power connection on the cluster. i wouold start with the fuse first..
1993 MB 190E 2.3 105k- its alive.. 1996 Volvo 855 GLT-R 350k still rolling
1998 Subaru Outback SUS 210k- Daily Driver 2011 Toyota Camry XLE 36k
1991 BMW 525I stock as stock gets 98k (Wrecked) 1998 MB C230 209k possessed by the devil
Benzworld.org---Tri-State Crew
Jippi is offline
post #6 of 7 (permalink) Old 11-05-2009, 02:14 AM
E-Fam's Avatar
Date registered: Sep 2009
Vehicle: 2001 E320 2011 E350c
Actually pull the fuse out and check it. Sometimes they can look good, but actually have corrosion hidden and cause your problem.
E-Fam is offline
post #7 of 7 (permalink) Old 11-06-2009, 04:50 PM
Date registered: Jul 2008
Check to see if your brake lights turn on. If they don't, its a bad fuse. The left side of the cluster and the brake lights are on the same circuit
YOkris3 is offline
    fuel temp and oil pressure guage not working bow129 W201 190-Class 2 07-07-2009 04:19 AM
    Wanted - 1985 300D turbo diesel - Oil Pressure / temp / fuel gauge cluster erikearle For Sale/Wanted/Trade/Giveaway 2 02-04-2009 01:10 PM
    Coolant temp/oil pressure Black Euro 500 SEC W126 S,SE,SEC,SEL,SD,SDL Class 1 02-28-2008 03:54 PM
    WTB fuel, Oil Pressure and Temp gauge Oneyeopn For Sale/Wanted/Trade/Giveaway 1 08-24-2006 05:38 PM
    oil pressure and oil temp sender NickT G-Class 6 09-03-2002 09:42 AM
