1990 190E Tune-Up - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W201 190 Class
Old 10-11-2009, 01:48 PM   #1 (permalink)
Date registered: Aug 2009
1990 190E Tune-Up
I have to get a tune-up and was wondering if the local tune-up place can do a decent job? I was told by the local benz shop it needs a major tune at over $500 which is a helluva a lot for me to afford. So can a local tune-up place do the job? If I can't afford the whole tune-up and need to do it in 2 steps what should I do first?
Thanks in advance
skorpyo is offline   Reply With Quote
Old 10-11-2009, 02:01 PM   #2 (permalink)
Benznoob26's Avatar
Date registered: Jul 2009
Send a message via AIM to Benznoob26
It'd be even cheaper to DIY and they aren't very difficult/dont require many tools.
Benznoob26 is offline   Reply With Quote
Old 10-11-2009, 08:03 PM   #3 (permalink)
Administrator
GermanStar's Avatar
Vehicle: GermanStar.net
Welcome to BenzWorld! I'll slide your query down to the W201 section, where you're far more likely to garner a helpful response from some like-minded enthusiasts. You might also consider completing your user profile, many find that information helpful in regard to providing you with the best possible response.
German Star Mercedes Parts
GermanStar is online now   Reply With Quote
Old 10-11-2009, 08:12 PM   #4 (permalink)
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6, bought 07/08 with 50k original miles.
Thanks in advance
Welcome to the forum.
Please click 'User CP' on the top toolbar and complete your profile with the car mod and location, to make it easier to answer your posts.
The forum archive has a wealth of information available at your finger tips.
The search function accepts 2 words of at least 3 letters.
For 'how to' / navigate the forum, please read the W126 tutorial, which applies to this forum as well Benzworld.org - Mercedes-Benz Discussion Forum - Announcements in Forum : W126 S,SE,SEC,SEL,SD,SDL Class
Cheers
Teutone is offline   Reply With Quote
Old 10-12-2009, 08:40 AM   #5 (permalink)
Date registered: May 2009
Vehicle: 93 190e 2.6
yeee theres this auto shop and they were charging like 600 bucks im like wtf they said its because its a mercedes and its an important. i told them how does that have any bearing on the car, a car is a car, doesnt require any "special" stuff for it and all japanese cars are IMPORTS, i was like wowwww
NYTM89 is offline   Reply With Quote
Old 10-13-2009, 12:38 AM   #6 (permalink)
W126 Forum moderator
Dr.Grillz's Avatar
Send a message via AIM to Dr.Grillz Send a message via MSN to Dr.Grillz Send a message via Skype™ to Dr.Grillz
Tune up usually consists of:
Spark plugs
Spark plug leads/wires
Air filter
Fuel filter
Distributor cap
Distributor rotor
oil/filter
I'm sure you could do all this for a fraction of what you were quoted. VERY easy to do.
Dr.Grillz is offline   Reply With Quote
Old 10-13-2009, 03:44 AM   #7 (permalink)
Date registered: Apr 2009
Vehicle: 96 E-320, 91 190E, various and sundry Euro and American vehicles
Wires are the pricey items on that list. They may not need done. Test at night with a water plant misting bottle. Spray water on the wires while running and see if you have a light show of spark arc. Visually inspect them as well. A OEM set can cost ~$80,oo or so.
Or you can find a good aftermarket set cheaper.
The other items are cheap.
Air filter can be a problem locating the right one, depending on the model. My 91 had a real offbeat one that was not on the books. What was called for and what was req'd were different.
You're looking at an hour of your time, if you are new at it. Few tools. A few screwdrivers and a socket set (with a plug socket).A oil filter wrench.
Total for the list above? ~$175.oo, and that is above and beyond tune (an oil change is not a tune up item, but smart)
aardvark.
aardvark is offline   Reply With Quote
Old 10-13-2009, 07:07 AM   #8 (permalink)
LAMF's Avatar
Date registered: Jul 2006
Vehicle: 96 C36, 87 Turbo'd 190E 2.3-16, 86 SC'd 190E 2.3-16, Brabus'd C32
and at the same time you can actually "tune" your air/fuel in a matter of seconds with an allen head, which the shop probably wouldnt do (or even know how to).
Dont take it to a shop just take a few minutes and save 600 bucks. If your local ill do it for a cookie.
87 190E 2.3-16 Cosworth- Track car-Getrag, short shift, delrin, 95a poly, Euro'd, 2 tone Recaros, custom suspension, EFI w/ Megasquirt, cast iron headers, Garrett turbo...
86 190E 2.3-16 Cossie-Old beater Getrag, slammed on BBS' Mosselman ECU, Eaton M62 SC
03 C32 ///AMG - Daily- designo edition, command, fulll Brabus CF interior, CF lips mirrors spoilers ect, and enough engine mods to destroy 911's
LAMF is offline   Reply With Quote
Old 10-13-2009, 07:26 PM   #9 (permalink)
Normally, I won't touch the air/fuel mixture without a CO meter.
Spray wd-40 to spark plugs, sit several hours or even overnight, head totally cool off, before remove the spark plugs.
Most spark plugs & ignition wires are with resistors now. 109e do not require double resistors. I purchesed @ NAPA copper ign wires & metal spark plug caps. Soldier the caps to wires. Total cost, $15, this are better than any ign wire sets.
bylaw is offline   Reply With Quote
Bookmarks
Just got a 1990 190E and I could use some help Chadwick Hudson W201 190 Class 32 10-11-2009 04:05 PM
just got a 1990 190e 2.6 ry_dawg W201 190 Class 7 03-10-2006 04:56 PM
Tune Up for a 1989 190E 2.6 rod528 W124 E,CE,D,TD Class 0 08-25-2004 11:04 AM
1990 190E 2.6 wae96 W201 190 Class 4 10-28-2003 09:52 AM
'87 190E 2.3 tune up ?s Guest (MBNZ) W201 190 Class 1 08-29-2000 12:10 AM
