Loud Clunking sound on driver side front wheel area? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 09-15-2009, 05:18 PM Thread Starter
Date registered: Jan 2009
Vehicle: 1985 190E 2.3
Hello,
I've got an '85 190E 2.3 that's in decent shape and I'm considering putting a rebuilt transmission in, but now the front wheel area on the driver side makes this loud clunk every time I drive over a pot hole or hit a bump. Any ideas?
I'm hoping it's the shock (which I have not replaced in 100,000K), but could it be tie rods, ball joints, or something costly along those lines?
Also, how much would it cost me to have a rebuilt transmission put in?
I had some quotes in the $2500 - 3000 range, is that about accurate?
I just don't want to make any payments, and I can't buy much for $2000.
Other than the transmission, is there anything (i.e. expensive) that I might be looking to replace on a car this old with 150,000 miles?
I just want to make a logical choice, so thanks for your comments!!!
wireless-101 is offline
post #2 of 11 (permalink) Old 09-15-2009, 05:24 PM
Date registered: Jan 2006
Vehicle: 1992 2.3 190E
Pot Holes - most likely the rubber bushing on the sway bar as it goes through the frame. Easy to fix and cheap at Autohaus.az
Let's see, drivers side. Crank the wheel as far as you can to the right and look for a bar.
Dan
Logon_Bob is offline
post #3 of 11 (permalink) Old 09-15-2009, 06:08 PM
chowbow's Avatar
Date registered: Sep 2008
Vehicle: 1992 190E | 1997 BMW 328i | 2001 C320 | 2004 C230K | 2007 BMW 335i
If it's only on bumps, I would also check out the top strut mount. Where the shock mounts to the body, accessible through the hood.
chowbow is offline
post #4 of 11 (permalink) Old 09-15-2009, 07:56 PM
Date registered: Dec 2008
Vehicle: 1993 190E 2.6, 1990 300SEL, 1992 300SE, 1992 400E, 1987 190E 2.6 murdered by my brother.
You can check if its the tie rods by jacking up car and seeing if the tire would wiggle when you move it left and right. Ball joints wiggle up and down so if you have that motion thats what it is. The clunk could be your old shocks bottoming out too. I had that clunk sound when I hit big pot holes hard by accident. It would rattle the chassis. Finally changed out the shocks to Bilstein Heavy Dutys.
There is one rule...there are no rules!
Runninrebel211 is offline
post #5 of 11 (permalink) Old 09-15-2009, 08:22 PM
Date registered: Jun 2009
Vehicle: 1991 190e 2.3L 8v
I'll say strut mount also.
gtone is offline
post #6 of 11 (permalink) Old 09-15-2009, 08:31 PM
Good call! I forgot about that one. When the bearing inside the mount seizes it can make that popping sound as well.
post #7 of 11 (permalink) Old 09-16-2009, 10:40 AM
chowbow's Avatar
There's no bearing inside the strut mount. It's just 2 pieces of metal and a big chunk of rubber. When the rubber breaks down and starts separating, there's the clunking noise from the bottom mount hitting the top of the mount.
chowbow is offline
post #8 of 11 (permalink) Old 09-16-2009, 12:29 PM Thread Starter
Thank you for all the responses!!! I will have the car looked at this weekend and I'll let everyone know.
post #9 of 11 (permalink) Old 09-16-2009, 12:37 PM
Chow bow you are right. I got it mixed up with my 1991 BMW 325i that had bearings inside the mounts. 190Es dont. Just a solid chunk of rubber.
post #10 of 11 (permalink) Old 09-16-2009, 08:10 PM
Date registered: May 2009
Vehicle: 1991 190e 1997 C280
Originally Posted by wireless-101 View Post
Hello,
I don't know where you are but I got a great transmission overhaul in the Dallas, Tx area for $1570.
ghartin is offline
    Creaking puzzle around front wheel, driver side! IFS W210 E-Class 7 06-29-2009 08:27 PM
    2009 ML350 Rear Driver Side Clunking Noise rgokhale W164 M-Class 3 12-08-2008 05:05 AM
    Engine oil leak in front of the driver side wheel kkau W210 E-Class 2 08-30-2008 06:38 PM
    ets bas lights on after clunking sound from brake area busoptr W163 M-Class 3 02-23-2007 11:54 AM
    While backing up and turning all the way to the right my front driver side wheel rubbed-loweredSport Danz R170 SLK-Class 20 06-11-2001 09:53 PM
