How hard to take out the automatic transmission - Mercedes-Benz Forum
post #1 of 26 (permalink) Old 09-01-2009, 07:05 AM Thread Starter
eameno's Avatar
Date registered: May 2008
Vehicle: 1992 190E 2.3 aut. white Benz
Hi,
Probably couple of guys in the form did this before. My question is how hard to take out a transmission? do I need any specail tool or anything? Meanwhile how much does the transmission weight?
Shortly can I do in my driveway durin a weekend?
Thanks
eameno is offline
post #2 of 26 (permalink) Old 09-01-2009, 07:50 AM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1046 Post(s)
You want the driveway drunk version or the professional way version?
DP is offline
post #3 of 26 (permalink) Old 09-01-2009, 08:48 AM
IR MODERATOR
Jippi's Avatar
Vehicle: 1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
Send a message via AIM to Jippi Send a message via MSN to Jippi
its heavy, its not to bad, you will need extra hands. i just did it to my dads volvo.
1993 MB 190E 2.3 105k- its alive.. 1996 Volvo 855 GLT-R 350k still rolling
1998 Subaru Outback SUS 210k- Daily Driver 2011 Toyota Camry XLE 36k
1991 BMW 525I stock as stock gets 98k (Wrecked) 1998 MB C230 209k possessed by the devil
Benzworld.org---Tri-State Crew
Jippi is offline
post #4 of 26 (permalink) Old 09-01-2009, 09:14 AM Thread Starter
eameno's Avatar
both work
eameno is offline
post #5 of 26 (permalink) Old 09-01-2009, 09:15 AM Thread Starter
eameno's Avatar
Could you please give me more clues or details ?
eameno is offline
post #6 of 26 (permalink) Old 09-01-2009, 12:04 PM
Date registered: Jan 2009
Vehicle: 86 190e 2.3-16, 83 380sec
Personally, I would recommend taking the whole engine and transmission out if you have a engine lift. On a 4cyl 190 you can get the engine and tranny out in less than an hour easy
bryceshaw is offline
post #7 of 26 (permalink) Old 09-01-2009, 12:12 PM
DP
DP's Avatar
My thought exactly!
Get a lift or rent it. It will be safer and also much easier to bolt the trans to the engine.
DP is offline
post #8 of 26 (permalink) Old 09-01-2009, 12:23 PM Thread Starter
eameno's Avatar
Do not I need to take exhaust and some other staff under the car out before tranny? by the way what about putting back? Wish there was a video or pictures explaining how could we do all this.
eameno is offline
post #9 of 26 (permalink) Old 09-01-2009, 12:31 PM
DP
DP's Avatar
Exhaust manifold to the exhaust system (four bolts)
Fuel lines (2)
Engine mounts
throttle link
Heater core hose
coolant hoses
Transmission cooling hoses
AC hoses
Harness
Disconnect the drive shaft
remove the trans mount
I guess this should do it...
Alternate solution: Car lift + Trans lift
DP is offline
post #10 of 26 (permalink) Old 09-01-2009, 12:32 PM
Kynyption's Avatar
Date registered: Jan 2006
Vehicle: 1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
If you disconnect your ac compressor you can leave it in the bay and remove the engine with out pulling off the lines and catching R12 or 134a to the face.
Just search for removing an engine/trans on youtube. Watch then do it on your car. It's universal. Pretty much if you see wires or plugs connected to the engine, mark them and remove them anything plugged in that leads off the engine gets removed, as well as the exhaust.
Kynyption is offline
    automatic shifts hard dryd8486 R170 SLK-Class 11 08-26-2008 07:56 AM
    Hard shifting G 320 96 Automatic Frank158 G-Class 2 03-05-2005 10:07 PM
    Automatic transmission question: anyone knows how to make the transmission shift at a higher RPM, DanPro1 R170 SLK-Class 8 10-07-2002 02:35 PM
    Prefacelift SLK: shift-knobs for automatic transmission can be installed on manual transmission? Marcello (Piacenza - R170 SLK-Class 3 04-26-2002 11:05 AM
