Stuck ignition tumbler solution... Alternate method - Mercedes-Benz Forum
post #1 of 28 (permalink) Old 08-27-2009, 11:09 AM Thread Starter
J300's Avatar
Date registered: Jun 2009
1993 190e 2.3
She has about 130k and the key was turning smooth and fine, but with out any warning the ignition tumbler is JAMMED. I mean STUCK!
So, I have read the shop manual and have a plan of action but need to know if any of you who have had to deal with the key not moving from position #0,
Have you ever done this, and had it work:
Originally Posted by shingleback View Post
If the key does not turn, try to estimate where the two holes in the lock cylinder would be, drill the cover plate at those points and remove the lock cylinder using the release wire. It may take a while but persistence will pay off.
I'm weary of drilling into anything before I can be sure it will work.
If my vibrating sander does not work, I am either going to do this or go for the full Un install procedure witch includes the gauge cluster and wheel.
J300 is offline
post #2 of 28 (permalink) Old 08-27-2009, 11:00 PM
Date registered: Dec 2008
Vehicle: 1993 190E 2.6, 1990 300SEL, 1992 300SE, 1992 400E, 1987 190E 2.6 murdered by my brother.
My 93 2.6 used to stick too when I try to start my engine. Used WD 40 to clean it out. Had to jiggle a few times while trying to take the key out, but Im not sure if yours is beyond that already.
There is one rule...there are no rules!
Runninrebel211 is offline
post #3 of 28 (permalink) Old 08-27-2009, 11:18 PM
IR MODERATOR
Jippi's Avatar
Vehicle: 1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
Quoted: 4 Post(s)
Send a message via AIM to Jippi Send a message via MSN to Jippi
dammit i gotta do that to my new car its a little sticky.. ive been putting it off for a while..
1993 MB 190E 2.3 105k- its alive.. 1996 Volvo 855 GLT-R 350k still rolling
1998 Subaru Outback SUS 210k- Daily Driver 2011 Toyota Camry XLE 36k
1991 BMW 525I stock as stock gets 98k (Wrecked) 1998 MB C230 209k possessed by the devil
Benzworld.org---Tri-State Crew
Jippi is offline
post #4 of 28 (permalink) Old 08-28-2009, 12:26 AM
Premium Member
ducatipaso's Avatar
Date registered: Jul 2006
Premium Member
Send a message via AIM to ducatipaso
ducatipaso is offline
post #5 of 28 (permalink) Old 08-28-2009, 10:15 AM Thread Starter
J300's Avatar
Yeah, I have ordered a new tumbler, just getting the old one out is hard because i have been trying for 2 days straight to get the key to turn from position #0 to #1 accessory on. If I cant get it today, I'm going to have to take wheel, gauge pod and surrounding plastics off and remove the entire unit.
J300 is offline
post #6 of 28 (permalink) Old 08-28-2009, 10:49 AM
Premium Member
ducatipaso's Avatar
Premium Member
keep twiddling with it. move the key slightly out [don't bottom it] and very gently jiggle it. also, ensure your steering column is not locked, and do NOT let it lock or you'll make the job harder. good luck.
post #7 of 28 (permalink) Old 08-28-2009, 03:12 PM Thread Starter
J300's Avatar
Steering column is locked and car will not move from park. Is this still a problem with the tumbler. hope so...
-Currently on Day 3 of trying to jiggle they key in the ignition trying to get the key to turn.
and the key works perfect on all locks and trunk.
J300 is offline
post #8 of 28 (permalink) Old 08-28-2009, 03:46 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1063 Post(s)
The problem isn't the key, it's the ignition tumbler.
You need to turn the tumbler to the 2 o'clock position if you want to have any hope of getting it out by inserting a needle to release the tumbler's spring so you can turn the ignition metal cover loose to expose the tumbler.
DP is online now
post #9 of 28 (permalink) Old 08-28-2009, 03:51 PM
Premium Member
ducatipaso's Avatar
Premium Member
hey J300 if the column is locked you'll need to move the wheel side to side to find the sweet spot where the lock pin is not loading up against the tumbler.
grab the wheel with your left hand at 12:00, rotate it back/forth gently while jiggling key and trying to gently turn towards on. The INSTANT you get it to go, do NOT turn it back. Follow my how-to and replace the tumbler immediately.
post #10 of 28 (permalink) Old 08-28-2009, 04:43 PM Thread Starter
J300's Avatar
Yep, thanks guys. Time to go try for another hour or so. If it does, I'll leave it in position number one and pull the tumbler. If it does not come loose in the next hour or so I'm going to get it towed, then remove steering wheel and gauge cluster and removing the whole assembly out and taking it to dealer for replacement.
J300 is offline
Tumbler changed - key stuck in the ignition again... MaxMatt W124 E,CE,D,TD Class 3 09-24-2009 01:21 PM
Alternate diesel purge method??? sbaert W210 E-Class 4 10-10-2008 09:26 PM
Alternate diesel purge method? sbaert W124 E,CE,D,TD Class 0 10-10-2008 08:10 PM
Ignition Tumbler ogGQ W126 S,SE,SEC,SEL,SD,SDL Class 2 08-22-2008 09:41 PM
Stuck trunk tumbler waybomb W210 E-Class 1 04-04-2007 11:26 PM
