190E 2.6: While running/driving, engine "stalls", tach dies, BUT..... - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 07-15-2009, 10:26 PM Thread Starter
lars-tetens's Avatar
Date registered: Nov 2008
Hi all -
FIRST OF ALL: Thanks to all for this forum. It helped me replace the Water Pump on my '92 190E 2.6, and I am 100% willing to coach anyone else thru it who may need help. Just send me a PM. (I am planning to post my lessons learned.)
Anyways, love my 190e, but it has developed a very intermittent (and disconcerting) stalling problem.
The symptoms:
Car running/driving smoothly, any speed, then suddenly, the tach falls to sero, and the car begins to stall (no response to accelerator), but...
1. The dash lights do not go on
2. "Coasts" almost like it is in Neutral (Power steering, etc still works)
3. Usually, within a few seconds (sometimes more 8-O), the tach jumps back up, and the car runs normally again.
This also happened when parked, and I tried to start it. Oddly, the car starts up - not just turns over, it starts and revs to normal - but immediately stalls, like I shut it off. This is readily repeated.
However, as a test: if I keep the key turned to "Start" (I dont recommend it), it appears to run normally - I can even rev the engine to keep it running.
Basically, it behaves as if I am turning the car off.
This sounds like it must be electrical - coil, perhaps? Or is there some sort of "kill" switch/relay that is tripping?
I have pored thru the (awesome and indispensable) online PDF MB Manual, but could find nothing.
Thanks in advance,
Bruce
'92 190E 2.6 201/103
"SAY HELLO TO MY LITTLE BENZ!!!"
lars-tetens is offline
post #2 of 19 (permalink) Old 07-16-2009, 06:07 AM
1987190E2.6's Avatar
Date registered: Nov 2007
Vehicle: 1987 Mercedes-Benz 190E 2.6
Ah-hem. OH DREWPROF? I BELIEVE WE NEED YOU FOR A MOMENT!
1987190E2.6 is offline
post #3 of 19 (permalink) Old 07-16-2009, 07:31 AM
lomtevas's Avatar
Date registered: Nov 2006
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3 and 2015 GL350 BTC
Quoted: 55 Post(s)
Send a message via Skype™ to lomtevas
I don't get it at all. I would have to run out of gasoline to get my 8v to stall. My 16v feels the same.
A petrol motor needs compression, fuel, timing and spark to run. My personal approach is to rule out each of these elements in reverse order. Use the look, feel and listen approach.
I would pull the plugs to see their condition. There are charts online that show how to read the spark plugs. Working from the plug to the wire to the cap, rotor, distributor interior and ignition coil/igniter, inspect each, disconnect each and see if spark appears. If you smell fuel, then the fuel delivery system probably works correctly.
A cheap timing light will reveal major mechanical failure.
Use a compression gauge to see whether the cylinders build and maintain pressure.
There is also the risk that more than one problem is working in concert so you may need some experienced help. Depending upon where you live, I am sure our Benzworld team would enjoy a road trip to help you check it out.
The home of the two 201's.
lomtevas is offline
post #4 of 19 (permalink) Old 07-16-2009, 10:07 AM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1046 Post(s)
ah yeah... stalling
mine will be no more I hope!
Bruce check out my Stalling Again thread, you may learn something and even perhaps find the problem. We got some really good people in here that know their stuff so hang in there and welcome to Benzworld!
DP is offline
post #5 of 19 (permalink) Old 07-16-2009, 10:42 AM
chowbow's Avatar
Date registered: Sep 2008
Vehicle: 1992 190E | 1997 BMW 328i | 2001 C320 | 2004 C230K | 2007 BMW 335i
Sounds like symptoms of a failed crankshaft position sensor. There are 2 of them on your car, one at the rear of the engine and one at the front. It is typically the rear CPS that fails. The front really is the TDC sensor actually. The rear CPS connects to the EZL ignition module on the driver's side strut mount area in the engine bay.
You can test the CPS using a multimeter although I honestly can't remember what the steps are. I'm sure you can find it from some searches. If you can't, post back. Some people have indicated that even if you do get a good reading, there's enough crud on it that you should remove it and clean it and it works well again.
chowbow is offline
post #6 of 19 (permalink) Old 07-16-2009, 12:42 PM Thread Starter
Hi all -
Thanks for the quick replies!
Drew, before I posted, I did a cursory look at your Stalling thread - didn't sound the same as mine (at idle, etc), hence my post. BUT, I just now did read through it - up to page 15 (out of like, 60?), and it still sounds different. More electrical than vacuum. But then again, this is my first Benz (out of umpteen cars of all sorts).
What was the ultimate outcome/problem? Vacuum? ICV?
My symptoms occur not just at idle or startup, but literally at any time. Recently, on a 3-hr trip, at 65mph, the tach just dropped to ZERO, the throttle was unresponsive, no lights (ala stalled) came on, it just starte to coast, like it was in neutral. Within 5 secs or so, the tach just jumped to life, and it was just as suddenly "all good".
The other time it happed (a couple days ago) - It was in the parking lot, at startup. It would start, then immediatly shut down, like I turned off the key. Waited a few moments (I opened the hood wiggled a few wires - unlikely it did anything) - and it fired right up.
I will look into the ICV (clean it, check hoses, etc), AND check out the CPS (same as the Camshaft Position Sensor? (that one went bad on my '92 Taurus SHO). I'd like to test it - the replacement at Autozone is Special order $78.
Thanks again, everyone!
Bruce
post #7 of 19 (permalink) Old 07-16-2009, 01:00 PM
Sincity's Avatar
Date registered: Feb 2003
Vehicle: '86 190E 2.3, '08 RDX, '09 C63 AMG
Mine used to stall intermitently when coming to a stop. I was able to start it right up again. I changed the OVP Feb and it hasn't happened since. However, my car is a 2.3.
FS: AMG Gen 1 w201 side skirts and rear skirt.
Sincity is offline
post #8 of 19 (permalink) Old 07-16-2009, 02:00 PM
chowbow's Avatar
Originally Posted by lars-tetens View Post
Hi all -
Bruce
Yes, that's the CPS. I would suggest ordering an OEM one from some of the online vendors though, usually a bit more robust. Autohausaz, Fast Lane, Buy MB Parts are good guesses and usually competitively priced.
chowbow is offline
post #9 of 19 (permalink) Old 07-16-2009, 02:46 PM
bballboy91's Avatar
Vehicle: 1987 190e 2.3L
Maybe you should tell him where to look in it....... thats a big a*s thread...
GO HABS GO!!!!
bballboy91 is offline
post #10 of 19 (permalink) Old 07-27-2009, 09:03 PM Thread Starter
Hi all -
Just a quick update: the 109E has been running well... until today.
It cut out on me about a dozen times on the way home. And "cut out" is probably a more accurate term than "stalling", in this case. Fortunately, If I am at speed, the RPMs or something allow it to not completely stall out, and within a few secs the tach would jump back up and it would run again. The prob came when navigating stoplights. :-(
Anyways! Chowbow, I think you might have called it. I am still debugging the problem, but am hopeful that the pickup/sending unit is just so crudded up that a good cleaning will help.
Like you great folks on the forum, the online PDF manuals are a godsend. It of course has detailed drawings and descriptions, and even the specs for the CPS itself. Range: 680-1200 Ohms - mine tested at 848.
Thanks, too for the tip on buying a replacement (if cleaning doesn't work) from Autohaus AZ. Great prices.
Stay tuned - I'll be pulling the sensor tomorrow to have a look at it!
Thanks again, everyone,
-Bruce
    Ahh bummer, "Check Engine" light already came on, driving through heavy fog K-A W220 S-Class 28 06-11-2008 03:37 AM
    No More "Kudzu": Cartoonist dies in accident Check Codes Off-Topic 0 07-11-2007 12:39 PM
    "i Just Bought Another Gwagen Thanks To Captian James Van Tach!" irantp4life G-Class 4 03-27-2007 03:40 PM
    Military Roof Rack and "bar" style running boards?? Je5ter G-Class 4 01-23-2007 09:40 PM
