So I have a 1992 Mercedes Benz 190E 2.6
Here's the issue. When driving it randomly downshifts, and occasionally disengages gears altogether.
i took it to a transmission mechanic, he doesnt work on mercedes, but he said that the transmission doesn't seem to be the issue as it does engage gears. With the check engine light on he said it's more or less likely a computer module or maybe a vacuum line. But without the right scanner he can't tell.
The fluid level is fine, and the fluid doesn't smell burnt at all, it is normal color.
So what do you guys think the problem is?
