To anyone that has a manual 190 or who has converted an auto to a manual. I am ready to fit a clutch pedal I have sourced and I understand the clutch master cylinder draws fluid from the brake master cylinder reservoir.
I just want to check I am going to connect it to the right spot, on the side of my brake reservoir is a nipple which it looks like I will just cut the end off and attach it to that with a hose clamp, only thing is, it doesn't look quite right as it is quite high up the reservoir, like 3/4 up. Is this the right spot? Cheers.
