Viscous Fan Clutch and Pulley - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W201 190 Class
Old 06-11-2009, 11:13 AM   #1 (permalink)
viejo1221's Avatar
Date registered: Feb 2009
Vehicle: 1995 C36 AMG
I have a couple questions about the Viscous Fan Clutch, and I realized that I had too many topics in my other thread. I'm learning, sorry.
How does it work exactly? When I first posted, I thought it wasn't working correctly because I thought that when you first start the car, the fan wouldn't need to spin. But after some more reading, my understanding is that the fan spins with RPMs at idle, continues to spin while driving until the Thermo viscous _______ (fill in the blank) reaches a certain temp at which point the clutch disengages and the fan spins free. So that when you're at highway speeds, airflow takes care of cooling and not the Fan with RPMs. Am I on the right track?
Haynes manual says that once removed the viscous fan clutch should be stored standing up. Haven't seen that anywhere else. Anyone know why?
What should I use to clean the front of the fan clutch that won't harm it? chowbow suggested to just use water, I'll try that tonight and see if I can get all that grease buildup off of there.
Lastly, I was putting the pulley back on to the bearing bracket and one of the 10mm bolts' head broke off. Should I just get 4 new ones from the hardware store? It's a new pulley but it didn't come with the 10mm bolts. I just thought that one of four bolts being different may cause a balance issue if they don't all weigh the same.
Thanks
w202 - 1995 C36 AMG
w124 - 1994 E320 sold
w201 - 1991 190E 2.6 sold
"I spent a lot of money on booze, birds and fast cars. The rest I just squandered." - George Best
viejo1221 is offline   Reply With Quote
Bookmarks
Viscous Fan Clutch Pulley Loose dpaterso W140 S-Class 2 05-22-2012 05:08 PM
Viscous fan clutch impossible to remove? Sergio W124 E,CE,D,TD Class 11 03-23-2009 06:21 AM
Viscous fan clutch Ken D W126 S,SE,SEC,SEL,SD,SDL Class 4 09-25-2008 12:46 PM
Viscous Fan Clutch Replacement, DIY... pcmaher W140 S-Class 7 05-03-2005 08:38 PM
viscous fan clutch briankim G-Class 11 08-06-2003 12:48 PM
