Replacing Voltage Regulator - 1993 2.3 - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 06-02-2009, 03:12 PM Thread Starter
Bimmerista's Avatar
Date registered: Mar 2007
Vehicle: 1996 E320
Hey guys....quick question. Do I need to remove & unplug this black cover on the alternator back to replace the voltage regulator? Or is the voltage regulator not in my line of sight from above where I'm standing?
Here is a pic of what I'm looking at when I'm looking from above. Any help is appreciated. I'm looking to complete this task within the next couple of hours when the engine cools.
Mike
1988 BMW 325is
1996 Mercedes E320
Bimmerista is offline
post #2 of 13 (permalink) Old 06-02-2009, 06:33 PM
jsbarks's Avatar
Date registered: Mar 2008
Vehicle: 84 190D
Mercedes Voltage Regulator Install
jack the car up of you need room and crawl under!
jsbarks is offline
post #3 of 13 (permalink) Old 06-03-2009, 06:42 PM
Date registered: Nov 2002
Vehicle: 1993 190e-2.3
Quoted: 40 Post(s)
How did you make out on replacing the voltage regulator on your 93?
Ignatz is offline
post #4 of 13 (permalink) Old 06-04-2009, 01:17 PM Thread Starter
Bimmerista's Avatar
Vehicle: 1996 E320
I didn't. I decided to put it off for another day.
Mike
1988 BMW 325is
1996 Mercedes E320
post #5 of 13 (permalink) Old 06-04-2009, 04:33 PM
Quoted: 40 Post(s)
Thanks for getting back. I knew you you change the regulator in the older alternators, but did'nt know if it could be done on a 93, with that black plastic cover. I'm at 200,800 and probably due for a regulator.
Ignatz is offline
post #6 of 13 (permalink) Old 06-10-2009, 05:08 PM
Quoted: 40 Post(s)
I got nervous with my mileage so I replaced my regulator. I dropped the alternator to make the job easier. The black cover has to come off to get to the regulator. Just take your time removing the cover so you don't break the tabs. I put a new belt on while everything was apart. My 200,000 mile regulator had one contact (brush) that was definetly short. I also dis-connected the battery before I started. Gota keep this junk runnin!
Ignatz is offline
post #7 of 13 (permalink) Old 06-13-2009, 09:06 PM Thread Starter
Bimmerista's Avatar
Vehicle: 1996 E320
Ended up taking my car to a reputable shop since I didn't have much time to perform this task due to work & whatnot.
The shop replaced the alternator & voltage regulator. All is fine for about 3 days, then this afternoon, while I was driving on the freeway going about 65MPH with the A/C on (it was about 100F in Dallas today) the ABS light faintly comes on. As soon as I turn it off, the light goes off. I could only endure the heat for about a minute, so I turn on the A/C again and within several seconds, the ABS light comes on again.
I park, do my errands, and come back out to a dead car. I have to get it jumped before I'm on the road again. Any idea what this problem may be??
Mike
1988 BMW 325is
1996 Mercedes E320
post #8 of 13 (permalink) Old 06-14-2009, 06:17 PM
Quoted: 40 Post(s)
Your going to have to run it by that shop so they can check out the alternator. Does'nt sound like its charging. I mounted a small digital voltage guage in my ash tray years back. Mines charging identical to the old regulator.
Ignatz is offline
post #9 of 13 (permalink) Old 06-16-2009, 07:43 PM Thread Starter
Bimmerista's Avatar
Vehicle: 1996 E320
"Charging System Failure"
Took it to 2 shops, they tested the battery and alternator....both told me the same thing. They didn't exactly know what the problem was and I was not prepared to leave it at the shop to get it fixed. Has anyone else had a similar problem occur?? What does "Charging System Failure" mean?? I already have a new alternator and relatively new battery. Both tested fine.
Mike
1988 BMW 325is
1996 Mercedes E320
post #10 of 13 (permalink) Old 06-16-2009, 09:08 PM
jsbarks's Avatar
Vehicle: 84 190D
what symptoms was yoiur car having again to make you think a charging issue?
jsbarks is offline
    What next changed voltage regulator no voltage Wayne4756 W124 E,CE,D,TD Class 5 05-14-2009 09:35 AM
    Does replacing Voltage Regulator increase Alternator life? rph74 W126 S,SE,SEC,SEL,SD,SDL Class 3 03-27-2007 06:34 PM
    Replacing voltage regulator/brushes my260e W124 E,CE,D,TD Class 5 01-01-2007 06:39 PM
    Replacing Voltage Regulator Sergio W124 E,CE,D,TD Class 3 11-24-2005 02:39 PM
    Help!! Replacing Voltage Regulator/Alternator Removal. Sergio W124 E,CE,D,TD Class 1 11-22-2005 06:54 PM
