Check engine light - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-23-2009, 05:24 PM Thread Starter
Date registered: Jul 2008
Vehicle: 1991 190E
Check engine light
Is there a way to find a code for the check engine light instead of taking it to a shop? If so what do you need to check it.
190E Dee is offline
post #2 of 3 (permalink) Old 05-23-2009, 06:55 PM
slk230red's Avatar
Date registered: Mar 2004
Vehicle: '01 SLK230,'93 190E 2.3, 1971 LS5 Corvette Convertible
Quoted: 31 Post(s)
My '93 doesn't have a check engine light, but the CFI Control Module still stores DTC codes and I can retrieve them using one of the homemade LED testers that has been discussed on this site.
Since yours has the check engine light then it probably has the built-in LED mounted in front of the battery. Press button for 2 to 4 seconds, note readout.
1 flash = No malfunction in system
2= Throttle position switch, wide open throttle contact
3= Engine coolant temperature sensor
4= Air flow sensor potentiometer
5= Heated oxygen sensor
6= not assigned
7= TD signal
8= Barometric pressure sensor
9= Electrohydraulic actuator
10= Throttle position switch, closed throttle position contact
12= Exhaust gas recirculation temperature sensor (California models only)
Info. from manual:
"The CFI control module monitors all the exhaust components of the CFI injection system and the exhaust gas recirculation. Malfunctions caused
by an open circuit or failure of one of these components are indicated by the malfunction indicator lamp in the “CHECK ENGINE” instrument cluster and simultaneously stored in the CFI control module.
A diagnostic connector (X92) with non-locking switch (2) and LED (4) is provided for this purpose on the right of the component compartment partition wall. When the nonlocking switch is pressed (ignition: ON) for
between 2 and 4 seconds, the flashing DTC output is initiated and the fault path indicated by the number of flashes.
After completion of the flashing DTC output, the LED shows a steady light. If the non-locking switch is again pressed for between 2 and 4
seconds, a further fault path can be indicated if it exists. If no further fault code is detected, the CFI control module switches over to on/off ratio
output.
Erasing flashing DTCs. Once a fault has been rectified without having
disconnected the CFI control module, the flashing DTC output displayed must be erased as follows:
When the flashing DTC output is displayed, wait 2 seconds before pressing the nonlocking switch for 6 - 8 seconds.
Note
Each flashing DTC output displayed must be erased individually.
Note
The non-locking switch and LED have been developed to enable customers and non-MB dealers to specifically pinpoint the fault path with “on board means” in conformity with legal requirements. An impulse counter scan tool
which indicates the stored fault(s) on a digital display has been developed for MB workshop personnel (see DTC output to diagnostic connector)."
slk230red is offline
post #3 of 3 (permalink) Old 05-24-2009, 12:33 PM
Date registered: Dec 2008
Vehicle: 1993 190E 2.6, 1990 300SEL, 1992 300SE, 1992 400E, 1987 190E 2.6 murdered by my brother.
My 1993 190E 2.6 has a button with LED right by the battery. Lift cover and hold down the button for a 5 seconds and let go. After if flashes keep track of how many times it does. Hold button down again after it is done flashing for 5 secs and then it will reset the Check Engine Light. Have to do this with the engine running or it will not work.
Runninrebel211 is offline
    2002 c 230 check engine light and srs light upstaterider2003 General Mercedes-Benz 4 08-04-2008 07:35 AM
    1997 S420 Fuel gage light flasehs setting Check Engine light aljabari W140 S-Class 7 09-03-2007 09:19 PM
    How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
    would blown dashboard light make check engine light go on? ae98 R170 SLK-Class 3 10-07-2006 12:36 AM
    check engine light & flashing fuel guage light pd99sl500 R129 SL-Class 7 02-27-2005 04:31 PM
