Rear Brake Change Questions - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-14-2009, 07:49 PM Thread Starter
Wizz190E's Avatar
Date registered: Nov 2006
Vehicle: 92 190E 2.6, 06 C280 , 87 Porsche 944
One of my upcoming "projects" will be changing out the rear brakes. I plan on doing the rotors,pads,and the parking brake shoes. Here are the questions....
Im planing on going with the the GENUINE Mercedes pads and ATE rotors. Is this ok ??
Anything else I should replace ?
Is it easy ?
Wizz190E is offline
post #2 of 5 (permalink) Old 01-14-2009, 08:10 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1052 Post(s)
Very easy!
Flush your brake lines when you get a chance; you should be doing that every year anyway.
DP is offline
post #3 of 5 (permalink) Old 01-14-2009, 10:49 PM
importfan21's Avatar
Date registered: Apr 2008
Vehicle: 1998 C43 AMG, 2006 E500 4MATIC Estate
Easy enough. Just make sure your parking brake is disengaged before you do it. I had mine engaged and it was a pain.
1998 C43 AMG @196k miles
2006 E500 4MATIC Estate @126k (DD)
1992 190E 2.3 @162k (SOLD, then STOLEN, then TOTALED)
1984 190E 2.3 (SOLD)
importfan21 is offline
post #4 of 5 (permalink) Old 01-15-2009, 03:46 PM Thread Starter
Wizz190E's Avatar
Guys does M/B make a rear hardware kit for these cars when changing brakes ?
Wizz190E is offline
post #5 of 5 (permalink) Old 01-15-2009, 04:09 PM
I think they do. Check out www.performanceproducts4benz.com
    Is it okay to change front brake pads and then change rear pads about a month later? jay (new jersey) R170 SLK-Class 5 07-17-2012 12:12 AM
    Help on change rear brake solsearch W211 E55 AMG, E63 AMG 0 05-08-2008 06:27 PM
    Pictures of Rear Brake Pad Change Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 9 06-02-2006 01:38 AM
    Brake Pad change questions Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 12 05-21-2006 12:17 PM
    560sec rear leveling and rear end brake fluid change 560sec_vroom The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 11-08-2005 01:45 PM
