ABS light stays on - Mercedes-Benz Forum
post #1 of 30 (permalink) Old 01-12-2009, 10:03 PM Thread Starter
Date registered: Dec 2008
Vehicle: 1992 190E 2.3L
Send a message via AIM to rsteckly
ABS light stays on
My abs light is on all the time. Do you guys know what that means and what to check for it? I replaced my brakes but didn't change any sensors or anything...
Ron
rsteckly is offline
post #2 of 30 (permalink) Old 01-12-2009, 10:21 PM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1120 Post(s)
Most likely your OVP relay (Over Voltage Protection Relay)
DP is offline
post #3 of 30 (permalink) Old 01-12-2009, 10:32 PM Thread Starter
What is the OVP?
When I changed the brakes, I didn't change the sensors...could that be it?
Where is the OVP--how can I fix it?
Ron
rsteckly is offline
post #4 of 30 (permalink) Old 01-12-2009, 10:47 PM
DP
DP's Avatar
ABS light on has nothing to do with the sensor pads but it could with the ABS sensors.
As to the OVP you are better off replacing it rather than fixing it. On mine, a 2.3L, the OVP is behind the battery hidden by a plastic cover.
This is what an OVP looks like
Location
DP is offline
post #5 of 30 (permalink) Old 01-13-2009, 09:42 AM
355190E26's Avatar
Date registered: Oct 2007
Vehicle: 1989 190E 2.6 (diamond blue metallic), 1989 190E 2.6 (blue green)
Quoted: 50 Post(s)
If you've recently tried to jump start your car you could have fried the OVP. Several friends of mine who own Benzes have had to replace theirs after jumping their car.
#1. 1989 190E 2.6 355 Diamond Blue Metallic, euro spec goodies, Borbet wheels, Koni shocks, Brabus W124 springs, Stromung exhaust
#2. 1989 190E 2.6 Daily Driver 877 Blue Green metallic, Euro headlights w/ HID projector retrofit, 15" AMG monoblock wheels, AMG replica body kit.
355190E26 is offline
post #6 of 30 (permalink) Old 01-13-2009, 10:28 AM Thread Starter
I did jump start it, but its been on since I bought it...
Hi,
Well, I've owned this car for a month and since I've owned it the ABS light has been on...I have had to jump it twice since I've owned it because the battery died...but again, it was on since I've owned it.
I'll replace the OVP...although I had trouble finding it on autopartswarehouse.com...a google turned up a universal one that I'm not sure will work.
Ron
rsteckly is offline
post #7 of 30 (permalink) Old 01-13-2009, 10:37 AM
slk230red's Avatar
Date registered: Mar 2004
Vehicle: '01 SLK230,'93 190E 2.3, 1971 LS5 Corvette Convertible
Quoted: 33 Post(s)
Originally Posted by rsteckly View Post
Hi,
Ron
Why not check the fuse on top first?
slk230red is offline
post #8 of 30 (permalink) Old 01-13-2009, 10:43 AM Thread Starter
Don't know how to tell if a fuse is gone or not
I would but I'm not sure how to tell...I showed the fuses to a mechanic who said they were fine...how can you tell if a fuse is gone (you are talking about the fuse box, right?)
Ron
rsteckly is offline
post #9 of 30 (permalink) Old 01-13-2009, 10:47 AM
slk230red's Avatar
Quoted: 33 Post(s)
Ron
Hi Ron,
No, on top of the OVP Relay you either have 1 or 2 fuses...look at the photo in post #4. The best way to check the fuses it to do a continuity check with a VOM. Usually you can tell by looking at the fuse to see if the link is broken.
Have you located your OVP Relay behind the battery? You can open the lid and pull the fuse out without removing the relay.
Another tip, if you pull the OVP Relay out of the socket, it probably won't go back in fully seated unless you somehow hold the bottom of the socket while pushing in the relay.
Dave
post #10 of 30 (permalink) Old 01-16-2009, 03:35 PM Thread Starter
Its off for now...but I'm not sure I replaced the right thing
Hi,
So I went to Kragen to try and find the right fuses...had to buy several emergency fuse kits for $3.99 each because they only came with one blue fuse each...but I have plenty of spares now!
In any case, I took a photo of what I think was the OVP relay. Its the thing in the little black plastic case right below the fuse box (I think). Both of those black boxes below the fuse box have two blue fuses each. I replaced the fuses in both.
rsteckly is offline
ABS light stays on c220guy W202 C-Class 14 03-23-2009 09:16 AM
ASR and ABS indicator light stays on, on my 93 SL500 Strick9 General Mercedes-Benz 0 10-17-2008 03:06 PM
ABS light stays on ... need help desperately Roughneck G-Class 5 05-22-2006 06:34 AM
ABS LIGHT STAYS ON, 1988 300TE gdeniro W124 E,CE,D,TD Class 6 09-02-2005 08:49 AM
abs light stays on tigger W220 S-Class 2 07-17-2004 09:22 PM
