Transmission or torque converter noise? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-12-2008, 01:48 AM Thread Starter
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 989 Post(s)
When the transmission shifts form first to second, I get after a slight delay, for a half to one second or so groaning / resonance like noise.
Its more pronounced and noticeable when the engine/tranny are cold.
Could it be the torque converter?
Has anyone here experienced this?
Recently changed the filter, transmission, and torque converter fluid to fully synthetic dextron VI.
Teutone is offline
post #2 of 2 (permalink) Old 12-12-2008, 05:32 AM
hamada128's Avatar
Date registered: Jan 2007
Vehicle: 93 190E 2.3, 94 E320 (sold), 01 E320, 99 S320
Quoted: 310 Post(s)
Check your fluid level. I had the same groaning noise in Reverse after a fluid and filter change and it was because of low fluid level.
hamada128 is offline
    Transmission Leak at Torque Converter Housing Gasket lca13 W202 C-Class 1 03-29-2008 06:28 PM
    Transmission/Torque Converter Removal robarco R/C107 SL/SLC Class 1 12-28-2005 06:12 AM
    Transmission Fluid Torque Converter Drain blackbenzo W163 M-Class 1 02-19-2005 12:53 PM
    Drained Torque Converter and Transmission Pan, also changed filter...how many quarts in '81 300TD?? GermanCarNut W123 E,CE,D,CD,TD,TE Class 7 04-25-2004 09:14 PM
    Auto Transmission, Torque Converter Fluid Change Guest (MBNZ) W124 E,CE,D,TD Class 0 12-04-2000 10:38 PM
