Rear Defogger Not Working - 1991 190e 2.6 Liter Auto - Mercedes-Benz Forum
post #1 of 26 (permalink) Old 11-09-2008, 03:49 PM Thread Starter
Jumanji99's Avatar
Date registered: Oct 2008
Can anybody with experience, tell me how to diagnose my defogger, Any information is helpful, i dont know even know where to start. The online manual i have is blurry and i cant even read the section with info on the rear defogger.?
Any help is greatly appreciated.
Jumanji99 is offline
post #2 of 26 (permalink) Old 11-09-2008, 04:40 PM
1987190E2.6's Avatar
Date registered: Nov 2007
Vehicle: 1987 Mercedes-Benz 190E 2.6
Check fuse #19.
1987190E2.6 is offline
post #3 of 26 (permalink) Old 11-09-2008, 04:50 PM Thread Starter
Jumanji99's Avatar
Fuse 19 Ok, Checked to see if any power was coming to the switch because it will not even light up, and No power coming from the wires that are connected to the rear defogger switch on dash.
post #4 of 26 (permalink) Old 11-10-2008, 11:02 AM
chowbow's Avatar
Date registered: Sep 2008
Vehicle: 1992 190E | 1997 BMW 328i | 2001 C320 | 2004 C230K | 2007 BMW 335i
Is your glovebox light not working as well?
chowbow is offline
post #5 of 26 (permalink) Old 11-10-2008, 11:05 AM Thread Starter
Jumanji99's Avatar
Yes, the glovebox light is not working. it used to..
post #6 of 26 (permalink) Old 11-10-2008, 11:12 AM
chowbow's Avatar
PM'd you back. Posting here for search purposes:
I'll bet you have an aftermarket radio too?
I just found this out this weekend when I did my stereo install.
On the factory stereo harness, there is a hot/12v power wire, color of wire is black and yellow. In the same bundle of wires, there is another wire which is also black and yellow, but I think it's a slightly smaller gauge. Those wires need to be connected together.
I cut off the entire harness plug when I did my install, and just connected the +12v to my headunit, leaving the wire for the rear defroster and glovebox (and who knows what else) disconnected. Once I connected the above mentioned wire to the +12v lead, everything worked again.
chowbow is offline
post #7 of 26 (permalink) Old 11-10-2008, 11:18 AM Thread Starter
Jumanji99's Avatar
Yes, actually i just installed a stereo and i think glovebox light went out around the same time, not sure though.
This is most likely the problem, i will check now
Thanks man, very very helpful,
post #8 of 26 (permalink) Old 11-10-2008, 11:35 AM
chowbow's Avatar
NP. Post back here to let us know if that solved it.
chowbow is offline
post #9 of 26 (permalink) Old 11-10-2008, 01:09 PM Thread Starter
Jumanji99's Avatar
Problem Solved, I did everything exactly as you described and rear defrost works and so does the glove box light. Thank you for your help
post #10 of 26 (permalink) Old 11-10-2008, 05:13 PM
chowbow's Avatar
Cool, glad you got it working.
chowbow is offline
    Can i put this a tranmission from a 1991 Auto 300e into my 1991 Auto 190e?? Jumanji99 W201 190-Class 1 10-24-2008 01:42 PM
    defogger not working CivicTuning2 W126 S,SE,SEC,SEL,SD,SDL Class 15 09-21-2006 11:32 PM
    FS: any part still left on 1991--190E 2.3 auto soco55 W201 190-Class 11 06-12-2006 06:54 PM
    Rear Parking Lights not working on 300SE (1991) BK.....Beamer Killer W126 S,SE,SEC,SEL,SD,SDL Class 0 01-22-2006 12:06 PM
    1991 190E 2.6 Auto Trans Governor Gear mikedl W201 190-Class 0 07-22-2005 04:15 PM
