Outside Temp Monitor - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 08-19-2008, 01:11 PM Thread Starter
Date registered: Apr 2008
Help again please. My 1986 190E outside temp display is blank.
I know the sensor is behind the front license plate. Is there a way to test the sensor? If so do you know what the reading(s) would be? If the sensor is good, and i need to change the display, How does it come out from the dash? Is it necessary to remove the dash assy? The maintenance cd i have makes no mention of the sensor and how to repair or replace it or the display.
Thanks again
Ruggs3
ruggs3 is offline
post #2 of 14 (permalink) Old 08-20-2008, 05:33 AM
frenchmanremy@hotmail.com's Avatar
Vehicle: 1986 Mercedes-Benz 190E 2.3-16V (3.0 Inline 6 swap)
i know that the sensor works with resistance, and that's how you test it, but, i don't have an ammeter, or voltmeter, or whatever you need to do that, so mine's blank too!
frenchmanremy@hotmail.com is offline
post #3 of 14 (permalink) Old 08-20-2008, 05:51 AM
Turnpike's Avatar
Date registered: Mar 2008
Vehicle: '87--190E 2.3-16v(being rebuilt), '99--C230 Kompressor
Quoted: 11 Post(s)
i just wish i could get mine to display farenhiet (sp) and not celcius (sp)
Turnpike is offline
post #4 of 14 (permalink) Old 08-20-2008, 05:57 AM
i don't care what mine is, as long as it displays!
post #5 of 14 (permalink) Old 08-20-2008, 09:25 AM Thread Starter
I'm trying to get the information in other places also. If i have any luck i'll post it right away.
Ruggs3
ruggs3 is offline
post #6 of 14 (permalink) Old 08-20-2008, 10:34 AM
shingleback's Avatar
Date registered: Apr 2006
Vehicle: '98 E300, '10 GL350 Bluetec
Test values
OC Resistance (ohms)
0 9798 +/- 98
20 3747+/-71
40 1598+/-40
Note: degrees C scale.
Sorry, I can't get the formatting to work. To test at 0, 20 and 40 deg C.
shingleback is offline
post #7 of 14 (permalink) Old 08-20-2008, 04:26 PM Thread Starter
shingleback, Thanks pal, i now have a place to at least start. Do you knoe if the dash has to be taken out to remove the monitor? Looks like it just slides in, but not sure.
Ruggs3
ruggs3 is offline
post #8 of 14 (permalink) Old 08-20-2008, 06:57 PM
Testing
1 Remove cover under instrument panel at the left.
2 Separate 3-pole plug connection of temperature indicator
behind instrument cluster.
3 Move ignition starter or glow starter switch into
position “2”
4 Test for battery voltage with voltmeter at 3-pole
coupling between lines 0.75 brown and 0.75 black/red.
If there is no voltage, repair interruption in line
0.75 black/red to cable connector interior or line
0.75 brown to main ground behind instrument cluster.
With voltage or ground connection indicated, separate
2-pole plug connection of temperature indicator behind
instrument cluster and measure resistance between the
two line plugs brown and green toward temperature
sensor (test values).
In the event of deviationes from nominal value, renew
temperature sensor together with electric line.
5 If electric lines, voltage supply and temperature
sensor are in order, remove instrument cluster and
renew outside temperature indicator.
OK, you get to translate from "service manualese" to English!
post #9 of 14 (permalink) Old 08-20-2008, 09:13 PM
Turnpike's Avatar
Quoted: 11 Post(s)
is there any way to get the temp display to go to farenhiet?
Turnpike is offline
post #10 of 14 (permalink) Old 08-20-2008, 10:32 PM
Date registered: Jan 2006
Vehicle: 1992 2.3 190E
I seem to recall this subject came up a long time ago and the answer was no it can't be changed.
Avatar says Delaware?? Not a US vehicle? All USA 's should be Fahrenheit. Seems to me, if you want it bad enough it can be done. There are parts cars around or a junk yard and pull all that's needed. Sensor and display unit should do it. Maybe the entire cluster, I don't really know. I would assume they function the same, wiring that is.
Dan
Edit: Shinglebacks How To says you can replace the sensor and or the gauge. I would assume now you can replace the gauge into your cluster and most likely order from the dealer.
mmm I just bought some mirrors from Nes and he asked me if mine was working. He's a salesman :-), I bought more than I went for. I believe he just may have one or two laying around. nescid1@verizon.net He also sells on Ebay.
Logon_Bob is offline
108 cdi temp fan / temp gauge problems merc 108cdi V-Class 5 07-01-2007 04:16 AM
A place for a monitor Boudzz W124 E,CE,D,TD Class 2 04-27-2006 12:37 PM
Need help for LCD Monitor frost_dxb W203 C-Class 1 09-20-2005 01:46 AM
Video Monitor Michilein W163 M-Class 19 11-13-2002 08:47 PM
When outside temp is higher than 40', how come the temp gauge still shows 40'? noelb W163 M-Class 5 04-16-2002 01:43 PM
