Runs Great / Won't Pass Emissions Test - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-10-2008, 09:35 PM Thread Starter
Date registered: Apr 2006
Vehicle: 1955 300SL, 93 300SE, 91 500SL, 1989 190E2.6
Quoted: 26 Post(s)
Cool Runs Great / Won't Pass Emissions Test
Well my 89 190E just fasiled its emissions test today, which surprised the hell outta me. It runs so well I was sure it'd breeze thru. Both the Hydrocarbons and the CO levels were too high. What could be the problem?
The spark plugs are new. I ordered today from AutoHausAZ the distributor cap & rotor. Maybe I'll get a bottle of Techroline and run it in the gas. Anyone other ideas?
sammywater is offline
post #2 of 9 (permalink) Old 06-10-2008, 09:45 PM
Illan's Avatar
Date registered: Feb 2008
Vehicle: 1987 190E 2.3
my money is on the catalytic converter
Illan is offline
post #3 of 9 (permalink) Old 06-10-2008, 10:50 PM
mfagus's Avatar
Date registered: Nov 2004
Vehicle: 1999 C280
Send a message via Yahoo to mfagus
My money is on the cat too.
What were your readings on the test? what did you fail on? NOX or ???
1999 C280
1992 Infiniti M30 Convertible
2008 ML320 CDI 4Matic
1996 Vulcan Classic
mfagus is offline
post #4 of 9 (permalink) Old 06-11-2008, 12:46 AM
IR MODERATOR
Jippi's Avatar
Vehicle: 1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
Send a message via AIM to Jippi Send a message via MSN to Jippi
how high is too high? what state are you in?
1993 MB 190E 2.3 105k- its alive.. 1996 Volvo 855 GLT-R 350k still rolling
1998 Subaru Outback SUS 210k- Daily Driver 2011 Toyota Camry XLE 36k
1991 BMW 525I stock as stock gets 98k (Wrecked) 1998 MB C230 209k possessed by the devil
Benzworld.org---Tri-State Crew
Jippi is offline
post #5 of 9 (permalink) Old 06-11-2008, 09:18 AM Thread Starter
Quoted: 26 Post(s)
runs great / failed emission test
Washington state. Hydrocarbons: at cruise, allowable limit 150 ppm, actual 285. Idle, allowable 220 ppm, actual 361. CO at cruise, allowable 1%, actual 7.5% and idle allowable 1.2%, actual 5.37%. OH NO not a catalytic! Those cost a lot of beans. I thought when a cat went bad, it got plugged up & car won't run. So maybe I didn't need to spend $75 on a dist. cap!
post #6 of 9 (permalink) Old 06-11-2008, 09:25 AM Thread Starter
Quoted: 26 Post(s)
Anyone know where to get a good deal on Cat?
It doesn't look like AutoHausAZ carries them!
post #7 of 9 (permalink) Old 06-11-2008, 12:20 PM
shingleback's Avatar
Vehicle: '98 E300, '10 GL350 Bluetec
Here's one: Walker Exhaust Info
shingleback is offline
post #8 of 9 (permalink) Old 06-11-2008, 02:42 PM
tonylinc's Avatar
Date registered: Oct 2005
Vehicle: 1955 300SL, 1999 SL600, 2011 C55 AMG, 1990 500SL, 1993 500SE
Quoted: 15 Post(s)
found some low cost replacements
there is one on ebay made by magnaflow for $65 and free shipping, & a few others closer to $100
Please don't spill Champagne in the Mercedes.
tonylinc is offline
post #9 of 9 (permalink) Old 06-11-2008, 03:08 PM
Date registered: Nov 2005
get and ebay or std universal cat - at worst they will have to rill a hole to put the o2 sensor in there (if it had one to begin with)
most likely its the cat - get that changed, get a new gas cap from like autozone and use some of that guarenteed to pass stuff you add to gasoline. tank up with premium and make sure the engine is hot when you bring it in.
remove any egr blocking things you may have put in there (I had a small screw in my egr valve hose in my old 93 190e )
some tricks include taking off the air filter and over inflating the tires
last option is getting a fake emissions from a shop you who does the stuff - if you know the owner personally for example. (I did that here in Ontario, CDN as the 190e was dying and I did not want to spend $ on it close to the end...)
good luck
messerchmidt is offline
    Need Help to Pass Emissions! Cat Problem? W202 C220 realog General Mercedes-Benz 3 01-06-2008 03:04 PM
    FS 1993 E300 Runs Great Looks Great, WI SuspectZero For Sale/Wanted/Trade/Giveaway 3 07-23-2007 10:28 AM
    exhaust header options that will pass emissions Yao W126 S,SE,SEC,SEL,SD,SDL Class 1 10-19-2006 02:11 PM
    How do W123 diesels pass emissions? Rickthecoinman W123 E,CE,D,CD,TD,TE Class 10 02-19-2004 04:20 PM
    500sel runs great, wont pass smog...what to do? Mr Maass W126 S,SE,SEC,SEL,SD,SDL Class 6 08-19-2002 08:17 PM
