climate controls - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-24-2008, 11:49 AM Thread Starter
Date registered: Mar 2008
climate controls
I have a 1986 190E and the climate controls stopped working. The fan switch also is not working. When you start the car the climate control buttons will light up. However when you turn on the headlights the lights on the climate control panel will go off. At the present time heat is coming out of the defroster however you cannot control the heat level since the temp dial will not adjust the heat level. I did a search on this but didn't find anything relating to the lights.
zeke33 is offline
post #2 of 4 (permalink) Old 03-24-2008, 12:52 PM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
Sounds like multiple problems.
You should probably check the heater valve, on the engine side of the firewall and the auxillary coolant pump near the coolant expansion tank and wiper fluid reservoir.
To check the fan speed switch and HVAC controller, you'll need to remove them from the center console. The HVAC controller has a separate fuse mounted in the rear corner that may be at issue.
MTI is offline
post #3 of 4 (permalink) Old 03-25-2008, 10:02 AM
shingleback's Avatar
Date registered: Apr 2006
Vehicle: '98 E300, '10 GL350 Bluetec
When my car did this I found a disconnected vacuum line under the hood, on the left wheel well.
shingleback is offline
post #4 of 4 (permalink) Old 03-27-2008, 10:02 AM Thread Starter
When I did a search some models had a 30 amp fuse in the engine comparment. Does the model have this fuse and if so where is it located?
zeke33 is offline
Climate controls B200T W245 B-Class 5 11-15-2007 12:43 PM
Remove Climate Controls fun 380 R/C107 SL/SLC Class 6 07-23-2007 12:53 PM
Climate controls for a 280CE Bev W123 E,CE,D,CD,TD,TE Class 0 11-22-2006 06:13 AM
hot climate controls yellobenz W123 E,CE,D,CD,TD,TE Class 3 04-22-2005 09:45 PM
Light behind Climate controls is out Marc W163 M-Class 3 07-17-2002 02:04 PM
