HELP!!!! White Smoke/Steam out of tail pipe. Head Gasket bad? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 11-27-2007, 10:34 AM Thread Starter
1987190E2.6's Avatar
Date registered: Nov 2007
Vehicle: 1987 Mercedes-Benz 190E 2.6
My 1987 Mercedes-Benz 190E 2.6 has been putting a white smoke/steam out of the tailpipe lately. I revved the engine up to about 4000 rpm in the driveway and I couldn’t see 5 feet behind the car because of a thick white fog of smoke. I don't know if this is important but the smoke seems pretty humid. I also noticed that some water came out of the tail pipe when I did this. I can’t drive it on the road to see if it will go away because it is not registered. Could this be happening because it has been sitting in the driveway for 5 months and water collected in the tailpipe or is it something more serious such as a crack in the block or a bad Headgasket?
HELP!
Kevin
1987190E2.6 is offline
post #2 of 13 (permalink) Old 11-27-2007, 11:14 AM
slk230red's Avatar
Date registered: Mar 2004
Vehicle: '01 SLK230,'93 190E 2.3, 1971 LS5 Corvette Convertible
Quoted: 33 Post(s)
HELP!
Kevin
To be sure it's the head gasket leaking coolant, you should see the coolant level decrease. Also, you can pull the spark plugs and compare them. The ones burning the coolant will look like they've been steam cleaned. I've experienced the same problem once on an Audi.
I just replaced my head gasket on my 190E 2.3 due to the other problem, oil in the coolant. Not a good situation, but I caught it early and everything turned out fine.
slk230red is offline
post #3 of 13 (permalink) Old 11-27-2007, 12:16 PM
lomtevas's Avatar
Date registered: Nov 2006
Vehicle: 1986 190E 2.3-16, 1992 190E 2.3 and 2015 GL350 BTC
Quoted: 55 Post(s)
Send a message via Skype™ to lomtevas
... it has been sitting in the driveway for 5 months ...
HELP!
Kevin
Sounds like oil leaked past the valve stem seals over the course of five months and upon ignition, that oil burned to smoke and spewed out your tailpipe.
I do not believe it's a cracked block because that would leak out oil and or coolant past the crack. Also, I do not believe it is a bad head gasket because the engine would stall too much to develop the heat necessary to burn oil trapped in the cylinders.
lomtevas is offline
post #4 of 13 (permalink) Old 11-27-2007, 12:45 PM
IR MODERATOR
Jippi's Avatar
Vehicle: 1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
Quoted: 4 Post(s)
Send a message via AIM to Jippi Send a message via MSN to Jippi
its probably from sitting. while my cars are parked i make it a habit to start them up once and a while. let the car run for a while and see if it goes away.
1993 MB 190E 2.3 105k- its alive.. 1996 Volvo 855 GLT-R 350k still rolling
1998 Subaru Outback SUS 210k- Daily Driver 2011 Toyota Camry XLE 36k
1991 BMW 525I stock as stock gets 98k (Wrecked) 1998 MB C230 209k possessed by the devil
Benzworld.org---Tri-State Crew
Jippi is offline
post #5 of 13 (permalink) Old 11-27-2007, 12:56 PM Thread Starter
I forgot to mention that NO it WILL NOT go away when warm, I let it run for 20 minutes yesterday and the smoke\steam was still present. I also remember about a year ago in October I was washing the car with it running and it was doing the White Smoke\Steam thing, but I thought it was normal. And if I remember correctly, the smoke\steam would disappear when being driven. Another thing is the water pump was replaced a couple of weeks ago and right after that, the Auxiliary Water Pump starts to leak. Also the car HAS been overheated a couple of times since I got it in February of 2005 due to failed auxiliary fans. You still gotta love a 190E 2.6 though, right? I don't know if this information is useful in determining my problem, but I thought I would throw it out there.
post #6 of 13 (permalink) Old 11-27-2007, 01:15 PM
z168's Avatar
Date registered: Oct 2005
Vehicle: M62
Quoted: 89 Post(s)
Rule of thumb:
thick white smoke = water has penetrated your cylinders
thick bluish smoke = youre now burning oil
theres a few different factors to see which one you have. could be the headgasket, valves, etc. have a qualified mechanic look it over if its a headgasket.
off hand its the headgasket - is there oil with your coolant? are you experiencing high running temps? (above the 100°C mark)
Deutsche Tourenwagen Meisterschaft
z168 is online now
post #7 of 13 (permalink) Old 11-27-2007, 02:40 PM Thread Starter
I think theres a possibility of Oil being in the Antifreeze Reservoir because the last time I looked at it, it was sort of dark out but I thought I might have seen a darkish-brownish tint in the Reservoir. I sure hope it's not time to put Klaus down yet. I thought there were plenty more good times to be had at 192,000 Miles.
post #8 of 13 (permalink) Old 11-27-2007, 02:48 PM
IR MODERATOR
Jippi's Avatar
Quoted: 4 Post(s)
check ur plugs.. what do they look like?
Jippi is offline
post #9 of 13 (permalink) Old 11-27-2007, 11:42 PM
Date registered: Oct 2006
Vehicle: '86 2.3-16 Cosworth
Send a message via AIM to ppetracca
Why would you have to put "Klaus" down? Headgasket failure isn't that big of a deal. It can be replaced for about $200 in parts and a weekend of your time. I thought it'd be pretty difficult but with these cars it's a fairly straight forward job.
ppetracca is offline
post #10 of 13 (permalink) Old 11-28-2007, 07:24 AM
Date registered: Apr 2007
Vehicle: 1989 190e 2.6 1993 500sel (sold) 1995 S500 coupe (sold) 1994 S500 blk/blk
Quoted: 15 Post(s)
Sorry to hear of this, but I am afraid you are going to have to "bite the bullet" on this one and replace the head gasket. The symptoms that you describe--the dark stuff in your coolant, white smoke coming out of the tailpipe, overheating at one time all point to a bad head gasket. But open the cap on your oil filler and look for emulsification on the cap. If there is, then coolant is getting into your oil which is bad news. Otherwise, as you explain it, oil is getting into your coolant which also is bad news. But there is a solution--replace the head gasket...the only problem is that it costs money, time and inconvenience. Good luck!
drcharlesatlas is offline
bad head gasket ... 300SE 1990 !!! Jabpir8 W126 S,SE,SEC,SEL,SD,SDL Class 6 11-27-2007 11:48 AM
White Smoke and Bad smell Htown W126 S,SE,SEC,SEL,SD,SDL Class 6 04-25-2007 06:16 PM
White Smoke..Is it the Head Gasket again? mcavs R129 SL-Class 2 11-29-2006 05:05 PM
Bad News !! Head gasket!! StarGazer W201 190-Class 10 09-11-2006 07:22 PM
Some White smoke/steam? andreifs W124 E,CE,D,TD Class 4 02-20-2006 02:21 PM
