No reverse-vacuum modulator problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-08-2006, 12:27 PM Thread Starter
Vehicle: 2001 ML55
OK, My reverse doesn't work. About 1 out of 10 days it actually snaps in and it will work the whole day. It's not slipping or worn out, just doesn't snap in. I can unplug the vacuum line to the modulator valve and it works fine then, except for the really hard shifts. I tried turning the modulator adjustment both ways, but it didn't do anything except change the firmness of the shifts. Before I replace this valve, I was wondering what it really has to do with going into reverse, I thought it just was for firmness of shift points? Anybody know?
jafo1994 is offline
post #2 of 3 (permalink) Old 12-10-2006, 01:04 PM
IR MODERATOR
Jippi's Avatar
Vehicle: 1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
Quoted: 4 Post(s)
Send a message via AIM to Jippi Send a message via MSN to Jippi
sounds like u need a new trans, my 85 had no forward gear and it turns out to be a broken band in the transmission. u mite want to check/change ur trans fluid.
1993 MB 190E 2.3 105k- its alive.. 1996 Volvo 855 GLT-R 350k still rolling
1998 Subaru Outback SUS 210k- Daily Driver 2011 Toyota Camry XLE 36k
1991 BMW 525I stock as stock gets 98k (Wrecked) 1998 MB C230 209k possessed by the devil
Benzworld.org---Tri-State Crew
Jippi is offline
post #3 of 3 (permalink) Old 12-11-2006, 04:53 AM Thread Starter
Vehicle: 2001 ML55
I've changed fluid and filter many times. I don't believe the tranny is shot. Some days it goes into reverse fine. If I take the vacuum line off the modulater it works fine. I believe it's not getting pressure built up, like a sticky piston or broken spring in the valve body.
jafo1994 is offline
For all those people who want to know where the Vacuum Modulator is! andy.cowman W201 190-Class 6 11-29-2006 05:55 AM
VAcuum modulator.... Samoila Stefan W201 190-Class 1 10-28-2006 08:13 AM
Vacuum Modulator Panther201 W201 190-Class 9 05-14-2006 06:55 PM
Vacuum Modulator on 280E Henk W123 E,CE,D,CD,TD,TE Class 1 10-04-2003 04:55 PM
Transmission vacuum modulator (300D Turbo) Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 3 04-11-2002 04:44 AM
