OVP Relay? - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 07-28-2006, 08:02 PM Thread Starter
Date registered: Jun 2006
Vehicle: 1984 190E 2.3
OVP Relay?
What exactly does this thing do. And if this relay were bad would the car still pump fuel and create spark? (because mine does, it just wont start).
I am having a problem with my car (see my other threads to find out more).
Thanks for the info.
Dracus is offline
post #2 of 15 (permalink) Old 07-28-2006, 08:17 PM
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
The over voltage protection relay provides constant power to the ECU to ensue the fueling system works correctly. It also powers other systems such as the ABS.
If faulty or not working the ECU will not read data from the engine sensors correctly and make incorrect adjustments – or no adjustments at all – often resulting in a rough idle or overall poor performance.
The relay has a 10 amp fuse that may have blown, check that first.
jdc1244 is offline
post #3 of 15 (permalink) Old 07-29-2006, 09:16 AM
Ruudje's Avatar
Date registered: May 2004
Vehicle: 2008 Outback 2.5 XT, 1999 A4 1.8T, 1980 244 GL
Send a message via Yahoo to Ruudje
Smile
is your check engine light on? Indeed, check that fuse first.... it could be a 50 cent solution to a much bigger problem
“One who conquers himself is greater than another who conquers a thousand times a thousand on the battlefield.”
Ruudje is offline
post #4 of 15 (permalink) Old 07-29-2006, 02:00 PM Thread Starter
Yeah the 10amp fuse is fine.
Oh and I have a 84 190E
Dracus is offline
post #5 of 15 (permalink) Old 04-24-2009, 09:31 AM
jsbarks's Avatar
Date registered: Mar 2008
Vehicle: 84 190D
TTT where is it?
jsbarks is offline
post #6 of 15 (permalink) Old 10-28-2009, 09:08 PM
Date registered: Oct 2009
Would all the above regarding the OVP relay also apply to a 90 300E?
Douglas39 is offline
post #7 of 15 (permalink) Old 10-28-2009, 10:07 PM
corey.hinkel's Avatar
Date registered: Feb 2009
Vehicle: 93 190e (2.3) 92' 300se, 2000 c230 , 1997 e430 93 190e (2.6)
search forum for how to fix
just take the casing off of the ovp, and resolder the connections on it, if they seem to have hairline cracks. this is a pretty easy fix, and will save yourself about 70 bucks. may be a good idea to just buy one for backup.
corey.hinkel is offline
post #8 of 15 (permalink) Old 10-29-2009, 07:34 AM
DP
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 1065 Post(s)
Most Benz if not all I think have OVPs.
Another way to tell if your OVP is toast is when your car has a hard time starting or if your ABS light is on and the idle goes crazy high when the light is on.
DP is online now
post #9 of 15 (permalink) Old 11-25-2009, 05:24 PM
Date registered: Nov 2009
Vehicle: '93 190e 2.3 171K miles, '95 Geo Prism 160K miles, '96 F250 7.5L 104K miles
my 1993 190e 2.3 has an OVP with 2 fuses on top. the printed circuit diagram on the can shows 2 relays plus a diode and a zener diode plus one icon i don't recognize but seems like it might be a control transister. i have several shop manual versions, but none show it. i've tried to test it off the car with a 12vdc battery, but am not certain of the connections. the fuses are good, ABS lamp is not on, engine runs fine, starts cold fine, but occasionally on a warm start will almost stall, then go to correct idle. so i'm trying to check out known week links.
motretu is offline
post #10 of 15 (permalink) Old 11-26-2009, 05:57 AM
Sounds like o2 sensor or possibly cts. Does it run rough for about 3-4 min then get slightly better? If it does my guess is the 02. I had same problem, it is most likely not ovp, but u do need to get a new one just in case
Where can I get an OVP Relay from? Falcon6 W124 E,CE,D,TD Class 12 09-28-2012 04:48 AM
OVP Relay & Fuel Relay tjuk W124 E,CE,D,TD Class 2 04-02-2009 05:36 AM
OVP relay MarkC W124 E,CE,D,TD Class 10 04-20-2007 10:45 PM
OVP Relay cherry420sel W126 S,SE,SEC,SEL,SD,SDL Class 3 06-25-2004 09:14 AM
What is an ovp relay??? Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 6 05-22-2004 09:32 PM
