Hi there,
I have an unusual one here.. (at least i think so)
I have a standard A150,
The central locking works fine, all doors open or lock.
However, the Drivers door will open (even when locked) if I double pull the handle.
I have tried the key in the lock and it does not engage with anything, (it can turn in an arc of 180)
So I realise that the lock must be in the "emergency access - open position"
It would seem to me the lock barrel has .. died so what can I do?
(It did work 1 year ago... I think I killed it then and it's been unlocked all this time)...
Can I disengage the lock and just have the Central locking working, or do I need to replace the lock?
I am happy to have a go on swapping out the barrel (if needed) but the internet seems confused as to what actually needs to be done.. from its only 3 screws to taking the riveted pannel off?
