» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W169 A-Class
Old 07-28-2009, 10:12 AM   #1 (permalink)
Date registered: Jul 2009
Unhappy ENGINE ERRRO CODE P0068
I have an 2006 A170, and after an oil change the engine light came on. A code reader comes up with the code P0068, MAP/MAF Throttle Position correlation.
does anyone know what this means? or what is the cause?
patelvi is offline   Reply With Quote
Old 07-28-2009, 11:18 PM   #2 (permalink)
Date registered: Mar 2009
Vehicle: A160 CDI
You didn't disconnect any vacuum hoses when you changed the filter, did you?
Mgr1 is offline   Reply With Quote
Old 07-28-2009, 11:23 PM   #3 (permalink)
Hi, thanks for the reply.The oil change was done at a garage, only the oil and oil filter were changed. I don't think the air filter was changed.
any ideas ?
Old 07-29-2009, 12:24 AM   #4 (permalink)
Vehicle: A160 CDI
I meant the oil filter, which is quite inaccessible behind the engine. Some piping could have been dislodged. The code could to be related to some barometric device, seemed like it when I googled it.
Old 07-29-2009, 12:21 PM   #5 (permalink)
Date registered: Feb 2009
Check out:
http://www.justanswer.com/uploads/vi...2124_p0068.pdf
A :-)
A170 Elegance auto, electric heated seats, bi-xenons
Andrew Chantrill is offline   Reply With Quote
Old 07-30-2009, 03:51 AM   #6 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
You undoubtedly paid top money for the work they did do? why not take the car back and complain, obviously the light wasn't there before the garage got their hands on it, I expect they are short of work and looking for a job or two so take care or they will stitch you up for something that doesn't need doing.
lofty is offline   Reply With Quote
Old 07-30-2009, 05:50 AM   #7 (permalink)
Strangely After a few miles of motorway driving >50mph the Engine light has gone.
And has stayed of for last 2 days, fingers crossed it does not come back on.
So I don't think it was a vacume leak? maybe a faulty sensor or the throttle position has somehow corrected itself? by using more open throotle on the motorway. only time will tell.
I have only had this car 2 weeks, bought from a non-MB private garage. They did an oil change for me, and put in Semi-Synthetic oil. So I will get this oil changed ASAP to a Merc approved fully synthentic oil.
Thanks for all the replies, some very good information.
just hope the fault does not come back.
Old 08-02-2009, 08:14 AM   #8 (permalink)
Spoke to soon, after another day the Message is back!
Same fault code. I am guessing it must be a faulty sensor ?
Any ideas ?
Engine Paint Code 75u406 Unimog 3 09-24-2008 10:41 AM
engine code benz_300se W140 S-Class 2 01-08-2008 06:46 AM
Engine Code Help... espo5166 W140 S-Class 8 04-18-2007 05:13 AM
check engine code 11? doggy99x W124 E,CE,D,TD Class 3 11-02-2006 04:19 PM
Check Engine code 26 petersed W124 E,CE,D,TD Class 1 10-13-2006 02:30 PM
