» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W169 A-Class
Old 05-03-2009, 05:50 AM   #1 (permalink)
Date registered: Apr 2009
Vehicle: a class 169 avantgarde , range rover lpg
A CLASS 06 RUST BUCKET
I AM FROM THE U.K AND HAVE STARTING TO SEE COROSION/PAINT FLAKING ON A 56 PLATE WITH ON 40,000 MILES FROM NEW ONLY , RUST IS ON BOTH DOORS , HAD CAR NEW 25 MTHS FROM DELIVERY MILEAGE, HAVE TAKEN CAR TO MERCEDES DEALER OTHER DAY , HAVE TO WAIT TO SEE OUTCOME , HAS ANYBODY HEARD OF THIS ON A YOUNG A CLASS, AND WHAT WAS THE OUTCOME ETC...?? I AMWARE OFF IT ON B CLASS THOUGH. HAVE POSTED PICS OF THE DOOR AND PAINTWORK IN THE NEW MEMEBER INTRODUCTION UNDER NEW UK MEMBER , THANKS FOR LOOKING , AND ANY REPLIES ON THIS MATTER WOULD BE GREATLY APPRECIATED INDEED
BEZZY0_0 is offline   Reply With Quote
Old 05-03-2009, 09:58 AM   #2 (permalink)
A CLASS ADVANTGARDE 56 PLATE RUST BUCKET PICS ADDED
UPDATED WITH PICS , ANYONE GOT ONE LIKE THIS ????
Old 05-04-2009, 02:16 AM   #3 (permalink)
Mr T's Avatar
Date registered: Oct 2008
Vehicle: W245 B150 SE
Saw your post in the other part of the forum, you are not far away from me.
That rust is terrible for a less than 3 year old car, I would be straight to the dealers to have them repair it under warranty - I don't see how they can refuse...!?
2009 W245 B150 SE Cirrus White
Mr T is offline   Reply With Quote
Old 05-05-2009, 11:30 AM   #4 (permalink)
J400uk's Avatar
Date registered: Jan 2009
They will repair it under warranty, no doubt about that. The cars are protected for 30 years against corrosion.
Apparently there is a problem that affect 2006/2007 A/B Class Mercedes. The motoring press in the UK havent said anything, but it has been reported in Germany.
J400uk is offline   Reply With Quote
Old 05-05-2009, 01:27 PM   #5 (permalink)
HI , THANKS FOR REPLY APPRECIATED , I WOULD LIKE TO HAVE ACCESS TO MORE INFORMATION ON THE GERMAN REPORTS DEALING WITH THIS ISSUE TO LOOK AT , HAS ANYONE HAVE INFO WHERE TO LOOK ? I AM 99 % ASSUMEING THEY WILL FIX IT , BUT THERE IS ALWAYS THAT UNCERTANITY THEY MAY COME UP WITH SOME EXCUSE ETC.. , THIS VEHICLE PAINT IS SUPAGARDED TOO. THANKS
Old 05-05-2009, 01:32 PM   #6 (permalink)
J400uk's Avatar
There is some more info on the B-Class section - http://www.benzworld.org/forums/w245...wner-rust.html
All of it applies to both the A and B Class, they are produced using the same parts in the same factory.
Old 05-05-2009, 11:58 PM   #7 (permalink)
thanks j400uk , info nice to have has i feel there will be a strong need to educate my local dealers if nec, has they will know nothing or very little about it , yeah , right!
Old 05-07-2009, 06:40 AM   #8 (permalink)
MERCEDES RANG TODAY, TO BOOK IN CAR FOR REPAIR , BUT EVEN IF THEY REPAIR DOORS ONLY , THIS WILL BE ONLY TEMP SOLUTION TO COVERING OVER UNDERLYING PRODUCTION MANUFACTURING ERRORS ,I FEAR THE RUST WILL RETURN , I AM PUSHING FOR REPLACEMENT DOORS , WHICH THEY WOULD DO IF CORRODED BAD ENOUGH THROUGH?? ALSO TRYING TO GET A FREE LOAN CAR WHILE IN FOR BODY WORK , THEY SAID THAT WARRANTY WORK DOES NOT GET YOU LOAN CAR ?
Old 05-07-2009, 08:00 AM   #9 (permalink)
J400uk's Avatar
I wouldnt worry too much about it as you are protected by the 30-year anti-corrosion warranty incase it does happen again. If they are repiaring them correctly I doubt the problem will re-occur.
As for a courtesy car, you should be entitled to one as your A180 is less than 3-years old. Usually it states in the terms that they have to give you one when your car is in for warranty work.
I think you might be better of phoning arround a few other Mercedes dealerships and seeing what they say.
Also, with respect, writing in CAPITALS is considered rude on forums and makes your post hard to read, so it would be appreciated if you could refrain from doing so!
Old 05-08-2009, 07:53 AM   #10 (permalink)
Derek Lecours's Avatar
Date registered: Dec 2006
Vehicle: B 200 & Audi A6
In Canada, all of the rusty doors are replaced and not repaired. This problem is well known and being addressed at the highest level. Go to the Regional rep and then higher if not completely satisfied.
Show some pics from the inside of the door edge. Some of those pics could be from curb rubs also.
Hold the camera parallel to the door edge to keep all in focus if possible.
2000 S Class Rust mcavs W220 S-Class 103 10-08-2009 10:40 PM
Rust Bucket Restoration Mike G. G-Class 13 12-14-2008 10:37 PM
Unbelievable! Man Finds Out His Rust Bucket is Worth $226,000! MBManiacz Off-Topic 21 11-17-2008 06:03 AM
2000 S Class RUST!!!!!! Warranty???? tgmnewry W220 S-Class 16 04-26-2007 09:52 AM
think i sold my 76 450 sl rust bucket mesanda R/C107 SL/SLC Class 12 09-25-2006 09:24 PM
