Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W169 A-Class
Old 05-18-2007, 12:11 PM   #1 (permalink)
Navi Retrofit Problem
I own a 2007 A150 model. I tried to retrofit a used original PLUG AND PLAY navi head which does not have the same part # , but looks exactly the same. It does not work although it should, as it is Plug and Play. Does anyone know if this is a programming problem, or what ?
EMH7746 is offline   Reply With Quote
Old 06-01-2007, 01:22 PM   #2 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
Contact Steve @mbenznl.com Steve has retrofitted the Comand to his A class
Mark Cummins is offline   Reply With Quote
Old 08-02-2007, 04:17 PM   #3 (permalink)
Vehicle: ML500
I assume you are in Europe
See my article on Mercedes Electronics upgrades, installation and retrofits
Assuming you had Audio-20 CD in, it is plug and play (but you have to add the GPS antenna), but the new COMAND will probably need coding (especially if it just turns off after displaying the logo)
If you had Audio-5 then you need to install converter harness, and connect the CAN lead to the CANbus distributor in left hand footwell
Cheers
Richard
RichardA is offline   Reply With Quote
A Class (w169) Navi Retrofit Problem EMH7746 Audio & Telematics Forum 1 03-21-2008 12:46 PM
REtrofit DVD Navi on my E220CDI W211 Kallekå Audio & Telematics Forum 18 06-03-2007 08:06 PM
navi problem jerrym Audio & Telematics Forum 2 01-24-2006 02:33 AM
Navi installation problem beaft Audio & Telematics Forum 3 09-17-2005 11:39 PM
NAVI PROBLEM AXIOM W211 E55 AMG, E63 AMG 0 03-16-2005 07:37 AM
