A140 2003 Engine Not Starting from Cold - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-15-2010, 03:39 AM Thread Starter
Date registered: Mar 2010
Hi.
I have a Mercedes A140 and have had it approx 1 month. When trying to start the car from cold, the only light showing on the dashboard is SRS. Try to turn the key and nothing.
Wait a couple of minutes and try again, sometimes it will start other times you have to try the same procedure 4 or 5 times before all the lights will come on the dash and you know you are ready for take off.
Does this sound like an ECU issue or is it a more technical electrical issue.
When buying from the garage the salesperson said that you had to press the clutch before starting, it was a safety feature (i reckon this is a load of baloney myself).
Also the car has 3 months warranty, so if its going to be expensive then would like to get it sorted under warranty before it expires.
Any help gratefully received.
Cheers,
DaddyCee
DaddyCee is offline
post #2 of 7 (permalink) Old 03-15-2010, 01:45 PM
brujobrc's Avatar
Date registered: Nov 2009
Vehicle: A 190 Elegance 2001 Gasoline
Location: San Carlos de Bariloche - Patagonia - Argentina
The lights works well? radio? honk? BTW the battery car is good? The fuses? Ear some click click when you go start? To press the clutch before starting, is true. Do it.
brujobrc is offline
post #3 of 7 (permalink) Old 03-16-2010, 01:57 AM Thread Starter
Yes the horn works fine, there appears to be no other problems.
We this happens, there is no clicking as if the battery is dead or discharged. It seems similar to if you try and start a car with the Imobiliser enabled.
Could it be a bad earth connection?
DaddyCee is offline
post #4 of 7 (permalink) Old 03-16-2010, 05:16 AM
brujobrc's Avatar
Haa ok nothing... if you push the car an try start in movement, start it? try. If one light goes on, horn, etc the battery and the ground are good.
brujobrc is offline
post #5 of 7 (permalink) Old 03-22-2010, 01:04 PM
Hi
I have similar Starting problem with my Merc A140 2001. Y reg.
Sometime when i am starting it doesn't starts. No error, or any wrong indication on panel. I have to then wait for 5-10 mins and then it starts.
This used to be often initially and now days this happens frequently.
Also there is second problem sometime my LCD (showing speed and temperature) doesn't light up.. totally no number.
I am more concerned with the first one - starting issue. How did u resolve yours?
Is there something called starter relay. where is this located?
Regards
Nilesh
neel is offline
post #6 of 7 (permalink) Old 03-22-2010, 02:41 PM
brujobrc's Avatar
If once works and others not, isnot a relay or fuse. Have some sound clic clic or not? if yes could be one relay, if not may be the inmobiliser or the key, have you the second key?
The cluster display on back have 2 connector may be are loose contact. The icons lights works? instruments? if only display not work may be the flex conector. Have you a scanner to chek it?
brujobrc is offline
post #7 of 7 (permalink) Old 05-07-2010, 11:27 PM
The Big J's Avatar
Date registered: Nov 2008
Vehicle: Quite a few ...
Switch on the back of the key. Common problem.
The Big J is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W168 A-Class
A160's cold engine starting problem vipe W168 A-Class 3 07-17-2009 04:04 AM
Slight grind noise when starting cold engine Silverbenzo C208/A208 CLK-Class 2 07-17-2008 01:03 PM
A140 starting from hot/cold problem steashy27 W168 A-Class 3 02-19-2008 06:22 AM
S500 engine noise when starting cold ec308 W220 S-Class 7 11-11-2006 12:53 PM
engine dies emidiatly after starting when cold Guest (MBNZ) W201 190-Class 5 03-22-2002 04:48 PM
