» Sponsors
» Sponsors
Old 10-27-2009, 02:36 PM   #1 (permalink)
Date registered: Oct 2009
a class HELP/ ADVICE needed
hello all,
New member who was wondering has anyone had the problems i'm encountering at the moment, i'v got a S reg A140 avant guarde.
the problem is with it cutting out/ stalling, last week it blew the ECM fuse causing the car to cut out and stall, i replaced the fuse and the car ran fine with no problems. that was last friday, then today whilst out in the car it lost all power and cut out, i checked the fuse but it was fine. the car turned over no problem but would not start. i then left the car for about 20 - 40 mins it starts no problem, it then ran for about 2 miles before it cut out again. then after half an hour or so it again started no problems and ran fine before cutting out.
i'v been to MB and changed the ecm & fuel pump relays with original MB parts and this has not cured it.
any other suggestions would be greatly appreciated before i take it into MB.
cheers Kev,
athertondragon is offline   Reply With Quote
HELP! What W220 S class should I buy? Advice needed. mercguy W220 S-Class 3 06-16-2009 06:37 AM
Potential C-Class customer, some advice needed Jade Falcon General Mercedes-Benz 7 06-10-2008 08:10 PM
Leasing 2008 E-class-- advice needed!! NYCAVS W211 E-Class 17 09-03-2007 03:46 PM
Advice needed ///S320 Detailing and Car Care 6 12-11-2002 08:43 AM
if u wanna to install S class rims in E class, any spacers needed? Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 09-26-2001 04:17 AM
