» Sponsors
» Sponsors
Old 09-25-2009, 03:15 AM   #1 (permalink)
Date registered: Sep 2009
Problems with A160 Model 2000
Hi
Could anyone recomend a good Merc Mechanic in Muscat, Oman? I recently bought a second-hand A class model 2000 Classic, which the clock said had only done 53k km. Now 55k. But recently, something went wrong (mechanically) in the drive side electric window as pressing the button does not do anything to the window but can hear the motor turn.
Secondly, today, the power steering failed and some lights came in inside like the battery sign and the radiator water light. Found out that the belt that runs the power steering mechanisam, alternator and water pump had come off. Could also see some fluid at the base of the engine which is most likely the power steering fluid.
What things should I bear in mind when talking to the mechanic. The Merc dealers are not very reputable here besides being very expensive.
Regards
Shajju
shajju is offline   Reply With Quote
A160 Air flow meter problems smugee W168 A-Class 1 06-13-2009 09:35 AM
hi people new member in uk with a160 problems danmantreacle New Member Introductions 1 05-25-2009 03:07 PM
Thinking about purchasing a USED 2000 S430, what options should I look for, any problems w/ 2000?... Guest (MBNZ) W220 S-Class 10 04-18-2008 10:14 AM
2000 A160 Transmission not shifting 630876712 General Mercedes-Benz 1 11-23-2007 07:28 PM
Is anyone who own a 2000 model ML>>>> JimB W163 M-Class 21 05-19-2003 06:10 PM
